Question about Kirby Ultimate G Bagged Upright Vacuum
Burning rubber smell when the vacuum is on.
I have a Kirby the Ulitimate G vacuum. It works fine but it gives burning rubber smell. Can anyone tell me what's wrong with it. I tried to open it but none of the Allen wranches fit it screws. Does it need a special wranch.
Thanks.
  • 15,935 Answers
Burning rubber smell is the drive belt.
there is either a physical binding in the belt housing (lint dirt etc.) or string/hairs around the pickup brush drum. give it a thourough cleaning and re-try.
Posted on Jan 11, 2009
    Genius:
  • 2,920 Answers
It sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Kirby upright smells like a foot. Changed the bags. We had to move it to the garage for storage beacuse it made the closet smell like bad shoes. Gets strong when used
Check the brush for accumulated hair, and other debris. If the brush is belt driven check the condition of the belt, over time the rubber deteriorates and melts when heated up during use creating a burning rubber odor.
Feb 24, 2011 | Kirby G6 Bagged Upright Vacuum
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
My Generation 3 Kirby Vacuum is giving off a burnt rubber smell when I vacuum. I have tried to raise the height of the head but it still happens. Can you tell me what could be causing rubber to burn? ...
The belt driving the brush roller in the power head is slipping. It is really just a big thick rubber band. Where it wears out it slips and burns due to friction.
Look at the bottom of the power head. There is a cover plate held with 2 to 4 screws. Remove the plate and you will see the roller and drive belt. Slip the roller out and remove the belt.
Go to your local vacuum dealer and get a replacement.
Installation is the reverse of removal.
Mar 06, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Smells like burning rubber when I turn on my G6 Kirby vacuum.
You must take of the plastic ends from the wood beater bar and make sure the metal axels are not wound up with hair. I did this monthly with 4daughters
Feb 15, 2010 | Kirby G4 Bagged Upright Vacuum
Making a burning smell...not working as it should
remove the brush roll clean the brush end bushings and replace with a new belt
Sep 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
The vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts dont appear to be broken but the one connected to beater bar seems like it may be loose
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542493
Generic problem for all Vacuums
Posted by mmetcalf on Apr 24, 2008
the vacuum turns on but wont run smells like burning rubber I took the bottom off and the belts don’t appear to be broken but the one connected to beater bar seems like it may be loose
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your question, the reason it smells like burning rubber is because the belt is too loose and it is burning the inside of the belt because it is to loose, the average belt change for a Kirby vacuum is every 4 to 6 months, the tighter the belt the better the cleaning and always use the genuine Kirby belts because they are designed to work with the Kirby, there are replacement belts that will work and are less but they are made to the correct size but Kirby vacuums always s work better with genuine parts. If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
679 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
