Question about Air Tools & Compressors
No air pressure in the air compressur
Iwent to use it and no air pressure at all air pressure will not build. my eye sight is bad so i could not read the directions that came with it.
    New Friend:
  • 5 Answers
Make sure pressure relief value is not pulled out
Posted on Dec 03, 2012
    New Friend:
    Problem Solver:
  • 8 Answers
See here this link may help you.. http://www.transitionsmobility.com
Posted on Mar 12, 2013
  • 1388 Answers
SOURCE: Will not build up pressure
If this compressor is dry type with no oil needed, then it may have a worn cylinder and/or piston ring. With flashlight in hand, look under cylinder with piston in upper most position. If you see scratches most likely it needs cylinder / piston kit. Not to worry, not too expensive. If you compressor has a crankcase with oil, then you may have problems with valves in the head. Cracked or dirt under headvalves will prevent pressure from building. Finally there may be one or several leaks in the tubing, check leaks with soapy water. enjoy
Posted on Nov 29, 2008
  • 1388 Answers
SOURCE: compressor runs and runs but only builds 40lbs pressure
At the web address below you will find a parts list of your compressor. The most likely problem areas are the tube seal and the piston/cylinder. The tube seal seals the discharge tube to the head of the compressor. It will fail over time and cause the problem that you have. (only costs a few dollars) The other problem that you could have is a worn cylinder. Your compressor is oil free thus the piston ring is made of silicone vinyl and wears depending on conditions at the job site. Heavy dust/ dirt will shorten the life of the unit. With unit unpluged and covers removed, push the piston to top of stroke and examine upper portion of cylinder. If you see groves/scratches install cylinder kit. (cost around 39 dollars) In most cases I would replace both the seal and cyl kit. These parts are also available at your local dewalt service center or on line at dewalt.com. The folks at dewalt are very helpfull. Good luck with your repair and email if you have more questions.
http://www.ereplacementparts.com/porter-cable-cpfac2040p-type-pancake-compressor-parts-c-129_1662_2199.html
Posted on Mar 26, 2009
SOURCE: craftsman 1 gallon direct drive oil filled wont build air pressure
It sounds like you may have a broken reed on the diaphragm plate. This is located at the block. Remove the cover, and look for a cast metal assembly with fins. It will be attached to the side.
Posted on Apr 23, 2009
  • 323 Answers
SOURCE: low psi in reserve tank on a dewalt air compressure
This is a fairly common problem in small pancake compressors. I would start by making sure no air is escaping from the condensation drain valve on the bottom of the tank.
Next Pump it up as much as it will hold and turn it off. Listen for air leaks around the fitting on the bottom of the regulator that screws into the tank. These really need teflon tape and to be screwed in well.
Next check the regulator itself. These are rather inexpensive and don't last long when the compressor is used a lot. Also it doesn't take much of a bang when jostled around.
Is the regulator for tank pressure set correctly? Thump the glass covering the dial with your finger. Sometimes it sticks and you'll think it's set correctly when it isn't.
Lastly, check each connection for tightness with teflon tape. If all looks good, gamble about $20 on a new regulator. Odds are that's where the problem lies. This has happened to me a few times.
Posted on May 12, 2009
SOURCE: Was working normal suddenly will not build pressure
Maurader1 an apprentice has this problem solved and is spot on. All these gurus and wiz need to stick to the basic and common sense. The first place your pump will give out after use or abuse is the gasket. All this garbage about defective reeds and defective pressure switch is a lot of nonesense if you first don't rule out the most common problem the head gasket. I'm cheap and this thing has paid for itself 10 time over. You can get a gasket kit for $7, but I fabricated a gasket out of the back of my notebook and sprayed some gasket spray and been working like a charm ever since.
Posted on Jan 04, 2010
I have a Dewalt model D55166. It will not shut off when it reaches the maximum allowed air pressure. What could cause this?
If safety pressure release valve pops open then electric pressure switch is bad, however if compressure keeps running and never pops safety valve then most likely tubing / joint leaks or cylinder / ring worn out. Spray soapy water on all joints and drain valve , if no leaks suspect cylinder. Good luck
Feb 23, 2015 | Dewalt Air Tools & Compressors
Air bubbles in sight glass but pressure is good
leak on intake line or bad seals in pump
May 08, 2012 | Hayward Pool & Spa
2008 honda pilot a/c is not blowing cold air, blows hot air. bought truck in 2007.
the most common problem with honda and acura is the magnetic clutch failure on the compressor , test to see if you are getting power to the clutch assembly with the car runningand the A/C on max if you have power the compressure clutch is bad if you don't ck the compressure fuse and or the clutch relay.
May 05, 2011 | 2008 Honda Pilot
When you change from heat to air , it still blowes hot air like it is not switching to air conditing, the compressure is running and lines get cold, but no cold air. thanks
If the orifice filter is clogged, this will happen, a better check can
be done with an ac manifold gauge set, the low side reads the
evaporator pressure and the high side reads the discharge
pressure. I had the same problem while checking the ac on a
2000 gmc 1500 z71 4x4. other things that could cause this are
to much oil in the ac compressor or not enough freon in the
system. an overcharged system , the best way to check it is with
a gauge that way you can tell if you have the right amount of freon
and oil in the system. plus the gauge set will let you know the
extent of your problem. good luck!
Apr 06, 2011 | 1999 Chevrolet Silverado 1500
How to calculate cfm of air compressure . we have required one air compressure having 7bar-10 bar pressure how much cfm it will have
If you are still looking for an answer to this question, here is a website that will explain how to calculate CFM of an air compressor...
http://www.ehow.com/how_5001852_calculate-cfm-air-compressor.html
Jun 26, 2010 | Atlas Copco LS 16 Hydraulic Cut-Off Saw...
Too hot little cold
Very possible your condenser is extreemly dirty and is turning off on a high pressure cutout. suggest you clean out condenser with compressed air. Brushing is not enough. also, check if condenser fan(at the compressor) is working.
May 21, 2010 | LG Heat cool Window Air Conditioner
Very hot compressure
Have frost on the compressor suction line moments after start, compressor unusually loud and labored, and overheating, means the system has been overcharged.
May 30, 2009 | Goodman CKL24AR24 Air Conditioner
Handy Master Fumes so Bad your Eyes can"t take the smell
It sounds like it's not getting enough air to fuel mix, check your lines.
Jan 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Rooftop unit economizer not responding. I tried to simulate hot ambient temperature, but compressor did not kick in, check the resistance of OAT sensor and it's good.
1.check spare parts of compressure.
2 check wireing of compressure.
3. check voltage.
4.check continuti of compressure.
5. check discharge pressure.
Apr 04, 2008 | Heating & Cooling
Air Tools & Compressors Logo
229 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
