Question about Sewing Machines
Bobbin tension on nelco - Sewing Machines
  • Sewing Machines Master
  • 1,564 Answers
Usually, it's the top tension you manipulate in order to get a balanced stitch. However if your bobbin tension spring is worn out it's rare to have to fix the bobbin tension.
So... start with your top tension. If necessary... such as in the case where you are using a rather fat thread or very fine thread.. you would locate a tiny screw on the bobbin case and tighten that.
Posted on Dec 04, 2012
I need help putting the bobbin threader back onto a Nelco JA38 sewing machine and the springs are giving me fits. Any help?
Not sure if you are having problems with the bobbin winder or threading the bobbin. This may help:
Nelco JA 38 Sewing Machine Threading Diagram
To avoid awful thread nests under the fabric, be sure to ALWAYS RAISE the presser foot when threading the top thread.
Interestingly, the bobbin threading instructions (above) show the bobbin loading into the bobbin case so it turns COUNTER-clockwise. This is the opposite of instructions for most machines. You can probably try both, the clockwise or Counter-clockwise,and see if one works better than the other.
Be sure to use fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil on your machine. Open it up, while gently wiggling the handwheel, drop a couple drops of oil every place that metal rubs against metal. Avoid plastic or rubber parts! You may even find little round holes throughout that are oil ports. Be sure to get the area around the needlebar, presser foot lifter, feed dogs, the bobbin area, and all the dial and selector mechanisms.
You can find manuals for your machine online (not free!).
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Aug 07, 2017 | Sewing Machines
I need the manual for a Nelco F600. Do you have it or know where I can get one. I was given a machine but think it has been in storage for a long time! Need to oil and check it out.
A manual for a similar model would be a benefit. Most machines operate and thread the same. Yes, you should definitely clean and lube your machine before trying any sewing. Tri-Flow Synthetic Lube from the hardware store is a good product to use because it does not dry out and turn to glue over time.
Nelco sewing machine manual free
Wheel on right side that controls the needle up and down is very tight...
FWIW, I inherited a Nelco J28 and it is the toughest machine in my arsenal. I repair horse equipment with it. The stitch quality is not the best, but it certainly sews most anything thrown at it. The only issue I have with it (and it is my issue, not the machine's) is that it has a side-loading bobbin which means the home position of the needle is also on the left instead of the middle. Having always used a centered needle makes using it seem somewhat unnatural. However, your machine appears to have the front-loading bobbin and centered needle.
May 16, 2017 | Sewing Machines
What's wrong with my Nelco 234F sewing machine. When I try to sew, the machine gets jammed and the thread is all tangled around the bobbin.
Install a brand new needle.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Generally, the top tension should be set at the midway point and then tweaked for your particular machine.
If you continue to have a problem, the machine probably needs service.
May 09, 2017 | Sewing Machines
I have an XN1700 sewing machine and I can't get a straight stitch underneath no matter how I adjust the tension what am I doing wrong? I've checked the spool and top threading .
Not sure I understand your question, but be sure to ALWAYS RAISE the presser foot when threading the top thread. This allows the thread to seat completely in the tension disk. Then, you may need to tighten the upper tension so the top thread will pull the bobbin thread up higher in the fabric.
FWIW, there are some machines that just naturally do not have a perfectly straight stitch. I have an old Nelco that creates a slight zag in its stitch. But, the machine makes up for this deficiency in other ways!
Mar 24, 2017 | Sewing Machines
when was your machine serviced last if it was a year or more spend the money it will extend the life of your sewing machine
Mary
Apr 12, 2014 | Sewing Machines
The bobbin on my Nelco SZ217 is not sewing
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 13, 2012 | Sewing Machines
My mother"ssewing machine willnot pick
I saw Nelco on this website http://www.sewusa.com/Sewing_Machine_Manuals/Nelco_Sewing_Machines.htm
purchasing /obtaining a manual is always very helpful when working with a sewing machine.
However, simple stuff to check, is the needle in the right way, with the scarf (groove) to the back?
Is the needle new and the right type of needle for this machine? Sorry, I don't know a lot about Nelco however, most machines use 130/705H system needles, but there is always the exception, especially with something 40+ years old so it pays to check it out.
And lastly timing, the needle needs to be down at the lowest point as the rotary hook comes around to catch the thread. If this isn't happening, then it could be that the timing is out on the machine. It's never happened to me but it can happen. But I'd suggest you try changing needle, check threading path and bobbin firstly.
Good luck.
Apr 10, 2011 | Sewing Machines
Made a mistake and took out the bobbin hardware that is held in by two little clips on my nelco sewing machine. it came out in two parts. I was trying to figure out why the tthread was breaking Can you...
Feel the edges with your fingernail on the one part with a sharp point (the hook). If you feel a burr this is where the thread is catching and giving you problems. Needs to be polished with a very fine crocus cloth or your fingernail buffer pad.
Lay the machine back some and put the hook in the hook race. That is the entire round part. The hook will lay opposite a c shaped metal piece in the edge of the hook race. Then put the round case on around it and snap the locks over.
Hope this helped.
Rick
Sep 05, 2009 | Sewing Machines
Sewing Machines Logo
135 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
