Question about Maytag MDE2400A Electric Dryer
Tumbler won star
Drum dont turn
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 03, 2012
2 Suggested Answers
  • 958 Answers
SOURCE: DRUM/TUMBLER ISSUE
look at the rollers of the drum, it could have been dameged already and needs to be replaced.
Posted on Mar 28, 2008
My maytag dryer is making a clicking noise and the drum won't spin. I just changed the belt and still not working
That's an interesting one. Does the motor run but does not turn drum? If the motor is running but the drum is not turning then there is a possibility that the belt is not attached to the idler pulley correctly. Go HERE to see video on belt install. I have also ran into the screws that hold the tumblers in the tub loose and making noise. Check to make sure there are no screws sticking out of the tub. Contact me at http://www.apcoplus.com/contact.php if you need more assistance or just comment back on FIXYA..
Apr 30, 2013 | Dryers
My HTC Vivid dont star and the screen is freeze
Well,you should take the battery out. Charge it completely and then turn it on. If it keeps happening try getting a new battery or go to your carriers store.
Jan 28, 2012 | HTC Vivid
Y olsdmobile lss 98 is on security light flashing and won t star how to fixed
put key in ignition and turn all the way like your'e going to start it but don't start it. the security light is going to be flashing. leave it for ten minutes like that until the security light turns solid(not blinking). Turn the key to off and then start it. The tumblers in the ignition lock cylinder are no good any more and the ignition switch needs to be replaced and reprogrammed.
Aug 15, 2011 | 1997 Oldsmobile Achieva
1999 F250 4x2 - was stored for 3 months and when I tried to move it - the right rear wheel turns but the left rear wheel won't turn. Took off the brakes and caliper - still won't move. I can move...
Hello, The rear rotor has 2 sets of brakes on it. The other thing is to look for slight movement in the driveshaft when it clunks. Depending on the rearend, some have to have both rear wheels off the ground to turn each side. And of course the trans in Neutral.
With the rear wheel you have an Emergency brake and a drum brake inside the center of the Rotor.
The rear of the brake backing plate has a rubber plug which is covering the Star-wheel adjustment for those drum brakes. You can try to loosen the Star-wheel to disengage the Emergency brake shoes. You can try pulling the brake cables toward the cab, to loosen the cables.
If this does not help, your Emergency brake shoe probably rusted off the brake mount and is jammed inside the drum. The linings fall off the metal like banana skins. I can tell you that if the Emergency brakes are a State safety requirement, you need to consider new rotors because the drum portion is usually trashed with rust.
I hope my Solution is very helpful to you.
Jun 11, 2011 | 1984 Ford F 250
Tumble dryer ,creda tcr 13
hello dave to do this you'll have to take the front panel off so you can pull the tumbler out so you can get to your pully and tensioner on the bottom on the dryer,loop the belt on the pully and keep tension on it while you slip the tumbler back in now loop the belt around the tumbler and after the tumber is sitting on your glides spin the tumbler till the belt is in place,if you can have somebody help you its easyer putting the tumbler back in with 2 people while keeping the belt on the pully on the bottom of the dryer. any other problems or questions let me know i've dont mine about 6 months age its a little pain in the **** but not inpossable
Apr 09, 2009 | Dryers
Fins fell off tumbler on Whirlpool Ultimate II dryer
Remove 2 screws under the lint filter cover, then using a spatula or similar, prize apart the top cover from the cabinet, lift top cover and support it.Turn drum by hand until the drum baffles are at the top, and refasten the baffles one at a time.
Then lower cover down and press until it is closed, replace 2 screwa under lint cover.
Job done.
Plz rate this soution.Thanks.
Jan 01, 2009 | Whirlpool Dryers
Tumbler Washer drum fills with water when unit is not operating.
yes the water vale is defective it has goten a little piece of sand of something in it and it dont take much replace the valve and the problem will be gone good luck
Nov 14, 2008 | Frigidaire ATF6000ES Front Load Washer
GE #DVL226EB6WW
Here is a link to parts and drawing for your dryer: http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
If the drum won't move, likely culprit is the belt
Jun 08, 2008 | GE DVL223EBWW Electric Dryer
DRUM/TUMBLER ISSUE
Mar 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE2400A Electric Dryer Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
