Operating system not recognized
BIOS doesn't recognize hard drive. Reseated hard drive but receiving same error msg.
  • 7,627 Answers
Remove HDD, test. Replace if necessary.
Posted on Dec 03, 2012
kakee
  • 1269 Answers
SOURCE: 0200: Failure Fixed Disk 0 IBM T-41
There's a possiblility that you can still recover your files. Try to plug your hard drive to a different PC and check if it detects it. Otherwise, there's no hope but to buy a new hard drive.
Posted on Jul 26, 2008
budmrtn
  • 11361 Answers
SOURCE: have an acer aspier 3620 - it is saying operating
Yes, you have hard drive problem, you get PXE error becuase when it cannot bootup from hard drive, it will try to bootup through he network instead. The hard drive must show up in the BIOS. You can verify by try it in another laptop if you can.
Posted on Nov 13, 2009
  • 80 Answers
SOURCE: Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Posted on Nov 14, 2009
  • 142 Answers
SOURCE: Gateway M-6843 laptop does not recognize hard drive.
The ticking sound is known as the "click of death". After a while the bearings in the hard drive get worn down, and the read head has trouble finding the data you want. In this case the drive puts the read head back to "square one" so it can try to trace its steps back to the wanted data. this makes a click noise. Thus the "click of death". Im sorry to say you need a new hard drive, and that your data is likely inaccessible without drastic measures. One method you can try is putting the hard drive in the freezer for 10 minutes. This will stiffen the bearings and may give you a couple of minutes to grab some data. You will want to have your new drive installed and windows loaded on it so you can readily access the data through a usb to sata/ide cable, which you can get on line fairly cheap. Other options are services like OnTrack, who have a team of engineers who open drives and pull the platters and try to get your data, but you are looking at thousands of dollars just for them to try.
Posted on Dec 31, 2009
SOURCE: bios not recognizing hard drive and cd rom. usb ports work
Hey I have the same problem, may have found a solution to this problem although im not 100% positive but read My post here in a reply to the same exact problem. Keep in touch with Me on this and maybe we can find a permanent solution
Posted on Feb 17, 2010
"the parameter is not correct" msg re WD My Book, unable to access
Try plugging it into a different computer to see what it does. Sometimes a computer's operating system will recognize an external drive differently if it has only a slight problem, whereas another computer's configuration may treat the problem differently. Some external hardrive software can get jumbled by the programs of a computer or sometimes even their own software programs can cause slight problems. It sounds like a software problem with bugs that can be ironed out. Also some computers will change the drive name to fit into the order of drives it recognizes. Good luck!
Jun 01, 2013 | Western Digital WD My Book Essential...
Ibm/lenova doesn't recognize my harddrive
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jan 15, 2013 | Computers & Internet
Toshiba satellite l750-16l "a disk read error occurred"will a new hard drive fix
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 06, 2012 | Toshiba Computers & Internet
Operating system not found
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.The hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Feb 02, 2012 | Microsoft Computers & Internet
Emachines D4362 starts only after many button pushes
Sounds like you might have corrupt window system files or the machine might not be recognizing the hard drive.
Press the DEL button to go into the BIOS. Go to the section that shows you the hard drive. If it doesn't show you a hard drive model and shows none then your hard drive is bad and would need to be replaced. If your hard drive is recognized in the BIOS then you'll need to try and reinstall windows. If you can't get windows reinstalled then the hard drive is bad at that point as well.
Jan 18, 2012 | E-Machines eMachines Desktop PC
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Currently have a samsung floppy drive device manager shows its installed but not showing in computer bios changed to make as default boot device system doesn't recognize it have a PANASONIC product...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to either swap floppy drive or boot up floppy seek both could be disabled press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
May 07, 2011 | Panasonic (JU-256A216P) (JU256) External...
My laptop crashed and we installed a new hard drive, as HP said, but we received a message that it did not recognize operating system. So we ordered recovery disks and put those in turned it on, still no...
ok, First you should understand the new hard drive is empty, it is not even formatted. At this point the most likely issue is the bios not recognizing the Hard Drive because the Bios is not set to automatically detect the hard drive. Enter the Bios and go to the hard Drive selection sub menu and have the computer automatically detect the hard drive size and type. Then go to the boot sequence menu and alter the boot order to CDROM, Floppy (If you have one), Hard Drive, Network. Reboot the computer and you should see the RAM test, hard Drive Identification and then the CDROM should start to boot. I can't be more specific about the steps because your post didn't include the model of the laptop. All of this assumes your CDROM is still in working order since HP laptops have a known issue with CDROM's going out for no reason. The hard way for dealing with this would be to get an encloser to put a hard drive in to make it portable and connect to another computer and do the partitioning and formatting of that new drive on the other computer and solve the problem that way.
Feb 16, 2011 | HP Computers & Internet
When i start my pc,it displays operating system not found
Go into the BIOS and see if the hard drive is recognized in there. If it is then try restoring it with the recovery disks. If the error still comes up then that means the hard drive is bad and would need to be replaced. Also if the hard drive is not recognized in the BIOS then that means the hard drive is still bad.
Apr 23, 2010 | HP Pavilion dv9812US Notebook
My husband's laptop shut down, and msg 'operating system not found' comes up on screen when turned back on....what should he do?
He needs to go into the BIOS to make sure that the hard drive is still being reocognized in there. If it is recognized then the operating system is corrupt and he'll need to wipe out the drive and reinstall the operating system and the drivers for his laptop.
If the hard drive is not recognized in the BIOS then that means the hard drive is bad and the hard drive would need to be replaced.
Nov 30, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
