Question about Rockford Fosgate Punch P325.1 Car Audio Amplifier
My Rockford fosgate p325.1 instantly powers sub to full power and does not release
SOURCE: Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Posted on May 29, 2008
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
blueextc3221
  • 15935 Answers
SOURCE: not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Posted on Apr 25, 2009
    laseramp
    • 309 Answers
    SOURCE: 401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
    the problem is mostly with your audio side of the amp. i have a 800 Rockford punch series amp hooked in series running at about 15 vdc at 2 ohms stable for now. but the amps left front power side transistors overloaded and smoked out, i will be replaceing my mosfets soon. Now on that side your issues apear to be related to the signal side of the amp. when you hooked the amp up tell me breifly did you hook the rca inputs to the back of the sterio and did you select the proper rca inputs for the amp? also note that amps have a potentiomater that can be tuned up or down to allow the volume or wattage to go up or down threw the system. if it's turned all the way down you'll here nothing. but often you'll get a pop sound or quickly see the speaker move a bit. this indicated the signal side of the amp has signal comming in but no output, just look for a turnable small screw inside the amp top or side. and turn up acordingly. note: to much output will damadge your system. not just the amp. ;)
    Posted on Aug 28, 2009
    • 10 Answers
    SOURCE: how do I hook up one sub to my rockford fosgate p3001 amp
    Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
    Posted on Jan 19, 2010
    I have one 12inch 1000 watt mtx sub what size amp should i buy
    Hello taona80,
    If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
    Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
    Rockford Fosgate T15004 The Amp still powers up with the
    Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
    Oct 27, 2009 | Rockford Fosgate T15004 Car Audio...
    2 12 p3d212 2 ohm hooking up to a rockford fosgate p325 .1 mono amplifier can it work? and how?
    Hello a_brake11,
    The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
    For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
    Hope this helps.
    Aug 26, 2009 | Rockford Fosgate Car Audio & Video
    Sub Wiring
    Hello jtkpay,
    Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
    Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
    Hope this helps. If it does, please rate as "FixYa".
    Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
    Rockford Punch HE2 wiring question.
    if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
    Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
    Help with CVR 12 (kickers) and a Power 1050 s amp (Rockford Fosgate)
    Send me your email account and i will draw you a diagram and send it to you there. I will need to know if the ohms of each sub as well as the amp. I'll also need to know if the subs come with one or two voice coils.
    Ciza
    Nov 04, 2008 | Rockford Fosgate Power 1050S Car Audio...
    Sub hook ups
    There's a lot more factors involved than that.
    • Power capability of the subs
    • Type/size of the sub box
    • Allotted space in the vehicle for the sub box
    • Voice coil impedance of the subs versus the capability of the amp
    • Etc.
    Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
    sub1 + -
    to      | |
    sub2 - +
    =      4ohm
               From Sub
                    Two
    amp (L) - + (R)- +
    Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
    Rockford Fosgate Punch P325.1 Car Audio Amplifier Logo
    Top Rockford Fosgate Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    Professor_V
    Professor_V
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
