Question about Frigidaire FEF352 Electric Kitchen Range
There's a f90 error code of my fridgedaire stove
  • Anonymous Mar 04, 2009
    When i tried to do self clean, it wouldn't lock the door, and then will give me a code F90, and keep beeping, when I press Clear/Off, it will jsut repeat cycle
  • damn_straigh Mar 05, 2009
    When trying to do self cleaning on oven, the cycle wouldn't complete, because the door won't lock. Will then give an F90 code, and won't stop beeping. Pressed clear/off, and it will just try to repeat the self clean cycle.
4 Suggested Answers
  • 1043 Answers
SOURCE: F90 error code Kenmore elite
The F90 error code is a door lock code. There are a couple of steps that you can take to try and clear the code. Do the following:
1) Unplug the range and wait for one minute.
2) Plug the range back in and turn it on.
3) Hold the door in and start a self clean cycle.
4) Wait for 2 minutes and then cancel the self clean cycle.
5) Do not let the door go until the door lock light goes out.
If that procedure does not clear the error code then you may have to get a Kenmore repair tech to take a look at the unit. There are a number of electronic fixes mentioned in their repair manual, but you would have to have the proper tools and training to run through those procedures. If there is any warranty left on the unit you can of course have the repair paid for. If not, then any repair shop should be able to give you a rough estimate on the cost of repair.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Posted on Feb 17, 2011
huuum
  • 750 Answers
SOURCE: fridgedaire stove fgf337ebd f10 code
Hello
Welcome ,
F10 Runaway Temperature.
(F10 only) Check *RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
You will need a professional diagnoses to determine the extent of this damage
Thank You Huum
Please remember to leave a solved rating before you sign off!
Posted on Dec 20, 2008
  • 111 Answers
SOURCE: Frigidair Electric stove (MN) CFEF358EC
F90-Maximum oven door unlock time exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch. 2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary. 3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam. 4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, repl;ace Lock Motor Assembly. 5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly. 6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch. 7. If all situations above do not solve probem, replace EOC.
Posted on Jun 17, 2009
Panasonic a/c
F90 = PFC control
Abnormality judgement: 4 times occurrence within 10 minutes
Location to verify: Voltage at PFC
Jan 26, 2014 | Heating & Cooling
Frigidaire oven error code
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
7. If all situations above do not solve problem, replace EOC.
Accessories For Audi
Jun 12, 2012 | Ovens
How to fix f90 code on Kenmore propane stove with digital display?
Hi.
F90 means: Maximum oven door unlock time exceeded. Test the wiring between EOC(electronic control) and door latch motor, check door latch micro switch.
Regards.
Ginko
Dec 16, 2011 | Kenmore Kitchen Ranges
When cleaning the stove i touched my accident the
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
F90 code flashing and i cant reset it
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jun 17, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
CODE F90
I have the same problem. my model number is Kenmore 970-556322. the whole stove is not working.
Oven door is not locked but got the message "door locked" on the control panel and won't allow reset via clear/off. and it shows F11 and F90 on the display, and the machine keep on beeping the whole day, tried to unplug and restart it next day, but didn't work.
Please help!
Jan 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Frigidaire FEF352 Electric Kitchen Range Logo
1,696 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
