Question about Dell (1W766) Motherboard
What type CMOS battery will fit a 1W766 motherboard
My Dell inspiron 8600 had to have the motherboard replaced. It was replaced with a motherboard from red_planet_motherboard on e-bay with a Dell Latitude D800 Inspiron 8600 Motherboard 1W766 motherboard. I am having problems finding a CMOS battery that will fit this motherboard connection. I have tried one for a dell inspiron 8600 and one for a dell Lattitude 800 of which neither fit. Can you tell me what Kind of CMOS battery will fit this new motherboard
  • Dell Master
  • 3,606 Answers
Hello here is the homepage:
http://www.dell.com/support/troubleshooting/us/en/ussoho1/Product/inspiron-8600
You have to order the battery from a dell service center.
It look like this:
what type CMOS battery will fit a 1W766 motherboar - 12_3_2012_11_08_08_am.jpg
But here could be a difference depeding how old the laptop is.
Here is the other type:
The dell dealer should know what right in your case.
Hope this will help you
Posted on Dec 03, 2012
Benimur
  • 6966 Answers
SOURCE: problem with the mother board.
A replacement motherboard for a Dell Inspiron 516 may be found at:
Pls confirm part number, availability, other related details and shipping cost.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 27, 2008
mstr2kx
  • 102 Answers
SOURCE: dell inspiron 3200 powers up but no picture on screen
Check the VGA Card that it's placed correctly and/or the VGA Cable is connected, then remove the battery of the MB, power up the PC then see what will happen, if it doesn't work then re-check the power cables to the motherboard.
Posted on Feb 28, 2009
SOURCE: Dell Inspiron 2200, power input broke on motherboard
HEY ALL THE PART NUMBER IS (PJ016) And here is where you can get it: http://www.parts-people.com/index.php?action=item&id=4109
Posted on Apr 21, 2009
  • 1027 Answers
SOURCE: my inspiron 5160 doesnt power up.
It should power up with the external power supply if it is working properly; you can remove the batteries and it should still work with the external source. If not, then the power section on the laptop is dead and needs servicing.
Posted on Oct 03, 2009
  • 115 Answers
SOURCE: I have a Dell Inspiron 1520 laptop. Fan has gone
that is absolutely right i work for the same and we charge $49 If you bought the sys. after sept. 2004. and you are out of warranty.***let me know what is the blue screen all about.and stop erros code with 0x000000** this blue screen will help us to understand the issue. and i can help you to resolve your issue.
Posted on Nov 06, 2009
When i open it said time off day clock stopped
Problem is with either the CMOS Battery or the Motherboard.
You can reset the CMOS battery.
You can replace the CMOS battery but if laptop is under warranty request for the Motherboard to be replaced.
If laptop is no longer under warranty I would suggest ask a local technician to have the CMOS battery replace which is less costly than replacing the motherboard.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 1525 Notebook
I need to change the motherboard battery on Dell 8100 laptop
sometimes there will be a compartment that can access the cmos battery sometimes not. This guide will show you in pic # 4 what the cmos battery looks like. If you look around the sit for a while you may find your specific laptop. I just don't have the time to look now.
Hope this helps.
http://www.insidemylaptop.com/take-apart-dell-studio-1537-laptop/
Oct 23, 2010 | Dell (S423) for Dimension 8100 (3F546)...
Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
Oct 12, 2010 | Dell Inspiron 1545 Notebook
What causes a dell inspiron 8600 to shut down and start up on it's own.
1.Memory problem
2.Battery total dead and loose contact of adapter power
check the adapter batttery connections
and next clean and replace memory(Ram)
Sep 17, 2010 | Dell Inspiron 8600 Notebook
Inspiron 8600 does not charge batteries. Power
hello
As you have mentioned that power supply is working fine then there can be only two things.
  1. Your charging module in the mother board is malfunctioning.And you cannot replace a particular module, you have to replace whole motherboard for it.If your system is under warranty Dell will do it for free.
  2. The connector which connects the battery with the mother board is gone.
hope this will solve your problem
Thank you.
Aug 16, 2009 | Dell Inspiron 8600 Notebook
Inspiron 8600 won't stay on for more than 3-4 seconds
Plugged up or on battery power? Battery: try removing battery and see if it does it. If it does, have the laptop serviced, could be a loose or damaged component. If it powers up and stays on without the battery, replace the battery.
Feb 28, 2009 | Dell Inspiron 8600 Notebook
Inspriton 8600, XP SP1a not recognizing Integrated Net Controller
try to run in safe mode.
press F8 key when u power up then enter s safe mode.
then remove sp3 f u enter success fully in safe mode.
then type in run "chkdsk /r"
then press enter "y"
then restart the computer.
Jan 12, 2009 | Dell Inspiron 8600 Notebook
Inspiron 8600 or 8600C
There is no P/N for the motherboard, it is only the model say chipset type, slot type, your processor type, etc that matters. anyway i dont think you can get dell's motherboards in any computer shops. the best is to call the dell company and ask them to do it. They might need your Dell model no and serial number which will be on the backside of the laptop. ADVICE it is best to buy a new one in such problems.
Jan 02, 2008 | Dell Inspiron 8600 Notebook
Computers & Internet Logo
105 people viewed this question
Alun Cox
