Question about Sewing Machines
Will not pick up bobbin thread singer 7642 - Sewing Machines
  • Sewing Machines Master
  • 1,564 Answers
It's out of time... have it repaired.
Posted on Dec 04, 2012
Rahul Sudhan
  • 30 Answers
SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
SOURCE: Singer 301a Bobbin troubles
I just had this problem, too - if you have the manual, check out page 15. If you have removed the throat plate, you need to make sure that the position finger on the bobbin case base enters a notch on the underside of the throat plate. Fixed my problem right away.
Posted on Mar 12, 2010
Testimonial: "You are absolutely spot on! THANK YOU!"
  • 36 Answers
SOURCE: can't pick up bobbin thread
Unfortunatlly if it will not pick up thread, it is possibly out of time. But before you go changing the timing, make certain it is threaded correctly, the bobbin is threaded correctly. If they are all good see my tip on time a sewing machine.
Posted on Jul 20, 2010
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
I own a Singer 258, the needle does not pick up the bobbin thread
is the needle the right one for the machine?
is the needle & thread correct for the fabric?
it's possible that the machine is out of time & would have to be retimed by a sewing machine shop
Apr 02, 2012 | Singer Sewing Machines
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
Can't pick up bobbin thread when I do manage to get the bobbin thread through . the machine works away making the holes but not sewing Singer 7462
Jul 19, 2010 | Singer 7462 Mechanical Sewing Machine
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
