Question about Dishwashers
Dishwasher wont turn on
The washer has no power
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 139 Answers
Check the bi-metal fuse on the main control board inside the door.
Posted on Dec 03, 2012
Whirlpool dishwasher wont turn on
first thing to do is to check if u have power to washer. check to make sure the breaker in your main electric panel is not tripped. If it is ok then take front cover off kick panel make sure that the wires running to the washer are not loose. be sure to turn off the breaker first. IF they are tight then turn on braker and check wires at washer connection with volt meter to see if u have power.
Apr 11, 2014 | Whirlpool GU2300XTS 24 in Builtin...
Dishwasher will not start
frist check to see if you have power you will need a tester , you should have 120 volts at the connection box lower right hand side , be careful it is HOT ! most times when a dish washer wont run it cause the door switch is bad and this is a very easy fix , turn off the power remove the inside of the dish washer door about 20 screws, most times you can see the door switch is broken and it can be ordered from this place http://www.appliancepartspros.com/ they ship same day i have gotten many parts from them good luck this is not a hard job just be careful of the power.
Jul 26, 2011 | Maytag Dishwashers
I havn't used my dish washer in over a year and it wont turn on. Why?
check to make sure you have power to the outlet, it should be located under the sink,, if you do not have power at the outlet then check the breaker in the breaker box.
c...
Jan 02, 2011 | GE Nautilus 24" Built-in Dishwasher
My dishe washer wont turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced
Now, if you have confirmed that the unit is receiving power from the outlet, and the unit is still not responding, this will lead to a failed control board, or timer module. replace either the timer, or control board, in this case.
Nov 05, 2009 | Dishwashers
Led wont light up. no power to dishwasher
Measure for 115 volts AC at the junction box behind the front lower panel where the incoming power connects to the washer wiring. If ok, you will need a wiring diagram of the washer to go further.
Aug 17, 2009 | Maytag MDB9600A Jetclean II Built-in...
Clean light blinks 7 times dishwasher wont turn on
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
Jul 23, 2009 | Dishwashers
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Jul 31, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
