Question about Kenmore Dryers
Getting an OL problem code
Every time we run the machine we get an OL trouble code. We tried the self diagnostic and it's supposed to go from C1 through C9 before it's finished and my washer shut off after C1.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
1. Unplug the power cord
2. Lift the top of the washer up, to do this there are 2 latches in the seams between the top and the bottom sections. These latches are about 6 1/2 inches from the right side and left side of the washer. You need to insert a small screwdriver (be careful not to scratch the paint) and push the latch while lifting the top section.
3. The top will actually fold back leaving the inner tube fully exposed. Support the glass lid so it doesn't get damaged because it is very heavy and will fall open when you flip the top back.
4. Remove the plastic top of the tub. There is one hose connected at the back and there are several snaps around the outter edge that hold it on. Remove the hose and unsnap the snaps and set it aside.
5. Remove the cap covering the very center of the agitator. It is just snapped in place and can be pryed off with a small screwdriver.
6. Remove the center screw under the cap.
7. Remove the agitator, you need to lift it evenly and might have to work your way around by pulling on one of the three fins and then the next and so on. I also had luck using a small pair of needle nose pliers and grabing a small lip inside the area where the screw was and pulling from there.
8. Remove the 6 phillips screws in the middle holding the plastic top gear in place. Be very careful you don't drop one of the screws because it can fall through the slots in the basket and be lost below.
9. Remove the plastic top gear.
10. Pull the plastic lower gear off of the splined shaft. It should pull right off.
11. Now you need to pull the basket up and off of the shaft. This is where you might have problems because the basket might be corroded to the shaft. If you can grab the basket on both sides under the outter lip and pull upward it might pull up. If not, then you will have to figure out a way to get it off.
12. Once the basket is off you will notice there is liquid inside of it. That is factory sealed in there so do not worry about that, it is normal.
13. With the basket is off you will be able to see that the shaft is probably corroded and the inside bearing on the basket is corroded. Clean these both off very good and check to see if the basket can easily go back on the shaft and slide up and down without getting stuck. I had to sand and file the shaft a little bit to get it totally cleaned up. The inned bearing of the basket is plastic so it is pretty easy to clean with light sanding.
14. Reassemble in the reverse order and your done. Check to make sure the basket can easily float now by pulling up on it from the top inside lips.
Posted on Dec 03, 2012
Where is the obd2 connector location on holden ra rodeo v6
Connect white (test lead) and black (ground lead) wires that are branched from harness approximately eight inches from ECM. After leads are grounded, the "Check Engine" light will flash the diagnostic trouble codes. The DTC's are indicated by the flashing CEL.
FLASH, FLASH, pause, FLASH, FLASH, FLASH = Code 23.
If only one diagnostic trouble code is stored, the DTC will repeat continuously until test leads are disconnected. If more than one diagnostic trouble code is stored, each DTC will repeat three times, starting with the lowest, then proceed to the next DTC. After all DTC's have been displayed, the pattern will repeat.I-MARK 84-85
Connect male and female test leads taped into wire harness near ECM. After leads are connected, the "Check Engine" lamp will flash the trouble codes. The DTC's are indicated by the flashing CEL.
86-87 Impulse located near the ECM connector, is used to actuate the Engine Control Module (ECM) trouble code memory within the module. Two terminals (A and C) of this connector are used to activate the diagnostic trouble code system in the ECM. With the ignition switch turned On, engine Off, connect a jumper wire between terminals A and C. The "Check Engine" lamp will begin by flashing a DTC 12. DTC 12 = flash, pause, flash, flash. There will be a longer pause and a code 12 will repeat two more times. This code indicates the self-diagnostic system is operating. The cycle will then repeat until the engine is started or the ignition is switched Off. In most cases, DTC's will be checked with the engine running since no DTC's other than DTC 12 or 51 will be present without the engine running. Remove jumper wire from ALDL connector before starting engine. Reconnect jumper wire after engine is running.
Throttle Body Fuel Injection
The ECM test connection is located under the center console.
A built-in, self diagnostic system will identify problems in the throttle body fuel injection system. When a problem is detected, the diagnostic system will illuminate the "Check Engine" light.
When the engine is started, the Check Engine light should turn off.. If the light remains lit, the self diagnostic has detected a problem. To determine where the problem exists, ground the "Test" terminal of the connector with the ignition On, engine Off and watch the check engine light. Each DTC will flash three times (lowest to highest).
Aug 21, 2014 | Holden Rodeo Cars & Trucks
Baumatic fault code E11 Baumatic BFLW75 60cm 7.5kg
Look under the machine, for a bag with the
diagnostic manual, they do not want you to find
You will need that to run a self check & get it working
again
Try unplugging the machine, but most likely it has
the codes stored on the circuit board
Aug 15, 2014 | Washing Machines
OL code and fixing it?
The machine may have a defective overload sensor.
Jul 21, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
How can i make the little red engine lite go out on my 2000 nitetrain?\r\nIt only comes on some times after a long hard ride i.e.100mi@90f temp. Oil tank is full only 2600mi since change. Thanks, G.S.
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
Jul 19, 2011 | 2000 Harley Davidson FXSTB Night Train
I cleaned the battery terminals as I appeared to have trouble with the battery. In disconnecting the ESP/bas , both airbag, slippery surface indicators all stay on and appears computer won't reset...
I'd try bringing it to any of the larger parts stores and ask if they can scan the codes (they usually do that free) After they have finished, ask if they can clear the existing codes. That should turn the warning lights off. The system itself goes through self diagnostics about every fifty miles or so. Likely if you do nothing except for driving it, once the on board diagnostics have self checked, it's likely the lights will go out by themselves.
May 15, 2011 | 2006 Jeep Liberty
Intermittantly when im in stop & go traffic my jeep 1997 grand cherokee will die (stop running). ill wait afew minuts and it starts fine & i usually get to my destination, but this is unacceptable....
self test is with the ignition key switch. you need to cycle the key off-on, off-on, off-on. The check engine light will flash out codes in pairs of numbers. The end of the test will be 5-5. report back with codes. But I'm betting its the crank position sensor.
Sep 27, 2010 | 1997 Jeep Grand Cherokee
Displays 104 when it is 65 control is whacky'is it sensor or thermostat, or what
Try this test for codes
Electronic Automatic Temperature Control Module Self-Test
  • The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A diagnostic tool must be used to retrieve these concerns.
  • The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
  • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
  • To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
  • To exit the self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
  • Always exit the self-test before powering the system down (system turned OFF).
  • Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Jul 30, 2009 | 2002 Mercury Grand Marquis
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
