Question about Technics RS-BX501 Dual Cassette Deck
RS-D225W Dual Cassette output cable - Technics RS-BX501 Dual Cassette Deck
4 Suggested Answers
  • 99 Answers
SOURCE: I need to know how to record 1 tape onto another
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Posted on Jun 29, 2010
caroldon
  • 17130 Answers
SOURCE: How to replace drive belts on Technics dual
First of all you will need some mechanical mind to open out the set. The tape mechanism has to be removed and the connections should be noted and removed. If the old belt is already in the mechansim then you will not have any issue with the direction of the belt to go around the capstan flywheel. If you have alreaddy obtained the correct belt then carefully open the back of the mechanism to remove and reset the new belt. When replacing check for the free running of the capstan if not use a small drop of oil to free. If the belt was not there then wind from the motor to the second flywheel after running it around the first flywheel to drag it along so that when the motor turns you have the flywheels turning freely. reset the back plate using a thin probe type tool to hold the belt and release to the motor. For a first time it may be a bit difficult but try again. Hope you get this right. Good day
Posted on Jul 20, 2010
skywavebe
  • 1258 Answers
SOURCE: Technics RS-TR272 dual cassette deck
Ahh, Another Dual cassette deck. These are typically not worth a repair charge. I went looking for a service manual but Hi Fi Engine did not have one but they had a Owners Manual. Any unit that has a specification as to wow and flutter starting new at .18% was never made to be a long lasting deck of any quality. I don't like to be negative about people equipment but you might be better off getting a better deck from the start. If you think it is worth the repair, then send it to someone but I don't think you will want to sink $100 into a unit like this.
I am not saying it is unrepairable but that with what you come out in the end you could have made a better choice for a deck to buy.
It is probably a bad solder joint or bad capacitor on the circuit board.
I am in Chicago and would look at it for you if you want.
Posted on Oct 17, 2012
Service manual for RS-BX501 Dual Cassette Deck
It's the first one on Google search. elekteotanya.com
Apr 03, 2013 | Technics RS-BX501 Dual Cassette Deck
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Technics RS-TR272 Dual - Won't Reverse
Cassette decks that have been sitting for long periods have problems with drive belts and idlers becoming slack or decomposing of the rubber compound. If you wish to keep the unit, please have it cleaned and have belts/idlers replaced with new ones by a professional service. Also have controls and switches cleaned of built up tarnish and mildew to prevent noisey or drop-out audio
May 11, 2008 | Technics RS-TR272 Single Cassette Deck
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Tape shows playing but no sound
Is sound at the headphone socket?
Does the meter show audio output?
If the answer is yes to these questions check that the connections to the amp are correct and the amp is set up is ok.
Regards
John
Nov 25, 2007 | Technics RS-TR272 Single Cassette Deck
Jun 09, 2007 | Technics RS-TR272 Single Cassette Deck
Technics RS-BX501 Dual Cassette Deck Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
