My maytag washer when spinning, the outer drum goes to the front right and stops moving while the inner drum moves. What causes that?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 139 Answers
There could be some clothes caught between the tub and the drum inside.
Posted on Dec 03, 2012
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Washer, front loader, Fridgidaire FWT449GFS1,
Hello, Welcome to FixYa. I suspect you are bang on and indeed it sounds like the rear bearing or spider gear is toast. It is a very involved repair either way but if you think you're up to it ( plus, is it worth it ? ) I can help in whatever manner possible with those frigidaire washers. I'll watch for your reply. Good luck. Regards, Macmarkus :)
Posted on Mar 10, 2011
Trying to diagnose a problem and have back panel off. Belt was off AND I think the cause is that the drum pulley and inner drum will not spin without a lot of pressure. I figure the motor (which appea
Either something is caught between inner & outer bowl or drum bearings need replacing. Also check outlet hose going to pump sometimes object caught there causing the bowl to be tight to turn.
Dec 11, 2013 | Maytag MAH2400A Compact Front Load Washer
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
When it spins, the washer makes a loud noise. it rattles. Also when it is doing the rinse cycle I can hear a vibration/rattling noise.
I'm sorry to say that tis is potentially very bad news. the problem you describe is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough then symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal at the rear
Jul 07, 2011 | Maytag Washing Machines
When the machine goes into spin cycle there is excessive vibration as if something was loose in the drum. Other wise the machine cycles fine. Is there someway to check for bolts or nuts loose on the drum....
Move the drum around by hand and listen carefully. There should be no loose bits or rattling, if there are it is possible that something has slipped in between the drums. It sounds as if the drum bearing may be failing. Grip the inner drum and move it up and down at the front while feeling for play relative to the outer drum. i.e hold outer drum and lift inner drum relative to where you are holding. There should be virtually no play.
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
Hi my washer does not drain properly. I think it used to pump the water out then spin the tub, but now the tube spins slowly when it is trying to pump the water out. Could something inside the transmission...
I would start with the simple possiblities first.
Remove the front cover (look for 2 phillips screws at the bottom of the front cover) Once you pull the screws, pull the bottom of the front cover forward until it disengages the two top retainer clips. This will expose the interior of the machine.
The pump is at the bottom right and has the hose from the drum attached and the other hose goes out the back of the machine.
The pump is opaque plastic and you can see if there's something jammed in the pump ( like a small sock). If it's "sucked a sock" it will jam the pump and will cause the drive belts (under the machine) to burn, stretch and not pump the water out. You can replace the belts by simply reaching under the machine and moving the electric motor a little.
If you've cleared the pump and changed the belts, try running the machine through a cycle with the front cover off and see if you've solved the problem..
with Maytag, this is usually the solution... If you're still not draining, you may have a small clothing article in between the inner tub and the outer tub... this will eventually block the drain on the outer tub and prevent water from getting pumped out..
You can use a straightened out coat hanger with a small hook bent on one end, take the top onf the machine loose (2 machine bolts hold the front corners down and tip it back away from the machine case. This will allow you to take the top cover off the outer drum exposing the space between the inner and outer drums. Take your "fishing rod" coat hanger and fish between the two drums on the right side near the drain hole... Most times you can snag and remove the blockage and pull it out.
Hope this solves your issue.. please let us know if we can help you further ...
Dec 02, 2009 | Maytag MAV2755A Top Load Washer
Progressively louder on spin maytag neptune model# MAH5500BWW serial#C8028996LC
You have a bad rear drum bearing ( unfortunantly , so do I ) . This involves removing the inner drum and outer drum . The complete rear of the outer drum , has to be replaced , due to the bearing is already installed in the new one . Very expensive to have done and very time consuming to do yourself . You probably should invest in a different washer . Front load washer manufacturers , have not come up with a way to support the front of an inner drum as well as supporting the rear also . Until this happens , rear bearing problems and excess expense for repair , will continue to be the downfall of front loading washers .
Nov 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag washer has a defect, technican told me, that lets water get between the tub and outer lining and sit there and stagnate smelling terrible.
The water always goes from the tub to the outer shell, that is where the pump connects. Put a little bleach in the tub with some water, shake the agitator side to side to move the drum enough to circulate the bleach around the tub. Then pump the water out and then lower the hose down to a bucket to get the last of the water out. Feel around between the inner and outer drums for anything that has jumped out of the inner tub to the outer drum. You should be able to push the inner drum aside enough to get your arm in. You may have to open the top to get your arm in the space.
http://www.pcappliancerepair.com/model-display.php Check this site for your machine.
May 07, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Not spinning properly
You will need to replace the inner basket and front outer tub assembly. Likely, the spider on the inner basket (drum bracket) has broken which is causing it to be loose and rubbing on the inside of the outer tub. This can be verified by checking for excessive play of the inner basket (hold the front of the inner basket and check for play by moving it up and down).
It's not a cheap repair unfortunately. Be sure to always use a small amount (2 tablespoons for a full load) of HE (high efficiency) detergent to prevent future build up which could cause corrosion of the tub spider.
Feb 01, 2009 | Whirlpool GHW9100L Front Load Washer
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
May 16, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
