Question about YouTube Videos
My ac and heater only works on high why? - YouTube Videos
Ac/heater onlu works on low
you either have a bad switch or bad fan motor. I would start by replacing the switch
Apr 09, 2014 | 1990 Toyota Corolla
1998 buick century my heater and ac fan only work on high i'm told it's the blower relays where are they located
they are not relays its a blower motor resistor a one piece unit usually held in by two bolts and an electrical connector either under the passenger side dash or behind glove box
Aug 03, 2012 | 1990 Buick Century
1997 Nissan 4 cylinder truck AC works excellent throwing snowballs cold air, then it will blow hot air. Relay switch and clutch has been replaced....Did not fix problem!
sounds like compressor isn't working properly or heater vacuum is opening vent to heater core.try turning on ac and if it cuts on and off repeatedly every few seconds the freon level is not correct or high pressure switch may not be working make sure radiator fan comes on when ac is on.if all this is working properly check vacuum hoses to heater may be opening vent doors to heater.hope this helps
Aug 11, 2010 | 2005 Nissan Altima
AIRFLOW KNOB FOR HEATER AC ONLY WORKS ON HIGH
you need a blower resistor. The motor may be bad, pulling high amps.
Jul 23, 2010 | 2004 Jeep Liberty
AC/Heater only works on high
the motor may have too much resistance to work on any other speed.
May 12, 2010 | 2006 Chevrolet Trailblazer Ext
Heater/AC blower works on high only
Blower housing resistor fried up.You will have to replace whole blower assembly.
Jan 04, 2010 | 2002 Chevrolet Impala
Blower speeds on ac/heater for 2003 chevy pickup(v6)
Hi, sounds like your blower motor resistor needs to be replaced. If not the resistor, check the blower motor.
Jul 27, 2009 | 2008 Dodge Ram Pickup 1500
YouTube Videos Logo
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
