Question about Singer Sewing Machines
Cg 500/550 BOBBIN THREAD - Singer Sewing Machines
  • 106 Answers
SOURCE: lost maual on singer cg-550
Have a look at this website.
If they do not have the manual you want email them and they will help.
The looping problem is the bottom tension is to slack, on the same website look at the repair section and it explains how to adjust the bobbin tension.
www.sewusa.com
Posted on Apr 18, 2008
SOURCE: Help cannot use my singer cg 590!
Threading a bobbin on a singer is backward to most other machines.
The thread goes under and you bring back through the 2nd slot and your home free . Had one for seven years and it wasn't worth anything after having a Kenmore verticle and then buying this one that threads actly backwards. Works fine after I figured it out. I use it for quilting.
Posted on Aug 10, 2008
  • 69 Answers
SOURCE: I have a singer cg
If you put the bobbin in the case with the thread coming off in a clockwise direction, the thread should just fall into a slot and gently tug on the thread and it will slide through the tensions. Lay it across the bobbin case and then pick up the thread with the needle.
Posted on Feb 12, 2009
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
  • 69 Answers
SOURCE: Excess bobbin thread under the fabric
I know you hate to hear this but you are probably threading it incorrectly. Make sure that the presser foot is in the up position when you thread the machine. This ensures that the tension discs are open and the thread makes it in between the disc.
Posted on Mar 01, 2009
I have a singer CG 590C. It didn't come with manual. I'm just learning to sew. My bobbin was hung up with thread when I pulled on it I pull the whole bobbin casing out. How do I get it back in? Help
First thing, you should probably get a manual for your machine.
Singer CG 590 Commercial Grade Manual
How to thread Singer CG 590
This machine is listed as a commercial grade professional sewing machine, so you are going to have some additional learning curve if you are just beginning to sew.
Nov 23, 2015 | Singer Sewing Machines
What should the tension be on for this machine?
Most of the time if the bobbin thread is coming through on top it means that the bobbin thread is too loose and/or the top thread is too tight and is pulling the thread too much. check and make sure that there isn't anything in the top tensioner that could be increasing the tension like lint. Good luck.
Feb 17, 2015 | Singer CG-590 Commercial Grade Sewing...
How to fix timing on CG 590 singer sewing machine?
It would be best to have a sewing machine technician do that; depending on your machine, it can be complicated to even to GET to the area to retime the machine.
Jul 22, 2014 | Singer Sewing Machines
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
I just purchased a singer cg-550/500 and after threading the machine and inserting the filled bobbin, I was unable to bring up the bobbin thread with the needle. I followed the instructions carefully but...
if im not mistaken, the bobbin when you place it in the bottom, you have to thread it is as well to the part where the needle comes down and collects and goes back up. please re-look at instructions for placement of bobbin
Mar 05, 2011 | Singer Sewing Machines
Feb 27, 2009 | Sewing Machines
Feb 20, 2009 | Singer 5050 Mechanical Sewing Machine
I have a singer cg 550 sewing machine and I am not sure which slot to put the bobbin thread in first
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
Singer CG-590
You can find a Users Manual plus a workbook that you can get in PDF and print. Users Manual is 44 pages and workbook is 58 pages. Go to www.mannualowl.com and search for Singer CG 590n manual. It's all free.
Apr 19, 2008 | Brother CS-8072 Computerized Sewing...
Sewing Machines Logo
96 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
