Question about Singer Tiny Tailor TT700
Tt700 bought this at a rummage sale...said it was hardly used...is there any lubrication required? feed dog doesn't work properly...the tension just turns and turns...I have the manual but it doesnt tell what kind of needle is used...I know its for 'mending' but it doesnt even sew...all the stuff is there...i wont give up on it cause i think it will be great for grandaughter who wants to learn to sew...do they make replacement parts for it? all the parts appear to be plastic...please resond to lregalia49@aol.com. linda
  • 3 Answers
It was hardly used for a reason. Everybody here got their's at a yard sale, thrift store, etc. Hmm, wonder why? Please don't give it to your granddaughter to learn on. She will only learn to hate sewing. Get her a forty pound, fifteen-year-old kenmore that will be a lot of tolerant. The Tiny Tailor is a little piece of large frustration.
Singer Red Band, regular point style 2020, size 14 needle. Insert flat side facing right.
Posted on May 05, 2009
The pressure foot pressure is not feeding the fabric. I have adjusted the tension but still not feeding the fabric. What else can I do?
Tension does not affect the ability of the machine to feed fabric, except in extreme cases perhaps when tension is too tight.
You probably need to adjust the presser foot pressure of your machine. Lighter weight fabric is more difficult to feed, therefore the pressure needs to be increased. (Heavy weight fabric will sometimes push the upper layer of fabric in front of the presser foot, therefore less pressure is required.) Even so, very fine slick fabric (silk, satin, chiffon) sometimes still needs additional help. In such cases, a roller foot, teflon foot, or walking foot may be beneficial. There is also the possibility that the feed dog teeth have been worn so they do not grip the fabric like they should. (Avoid running the machine without fabric between the presser foot and feed dogs to protect the feed dogs from unnecessary wear.) If they are worn, usually they can be replaced.
Another possibility is that the feed dogs do not raise as high as they should. This would most likely require a technician's assistance.
Um, as an additional thought, make sure the presser foot surface is smooth. Any rough surface (nicks, rust, etc) will restrict the fabric's ability to move.
Jan 30, 2017 | Sewing Machines
Feed dogs up?
If the feed dog lever does not raise the feed dogs, then they are probably stuck. Probably needs lubrication. Since the make/model was not specified, would recommend taking it for service.
May 11, 2016 | Sewing Machines
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
Bernina 830, How do I raise the feed dog?
Feed dog selectors on older mechanical machines often become stuck with age, lack of use, and lack of oil. Do a thorough clean and oil of your machine (see your manual for where to oil) using a good quality sewing machine oil (not 3-in-1, WD-40, or cooking oil). If it hasn't been oiled in quite some time, a good penetrating oil such as liquid Tri-Flow Synthentic Oil from your hardware store can be used. Do not use more than one or two drops at a time and do not oil the metal cams or the two white plastic gears. To further loosen things up, direct a hand-held hair dryer on a hot setting into the internal mechanism of the machine. You may need to repeat several times and let it set overnight, but if it is old oil that has gummed things up, it will usually loosen up with oil and heat.
Recommendation is to oil every time a bobbin thread is changed, every 8 hours of constant sewing use, or every six months if not in use.
Also note, sometimes the feed dogs do not raise until you begin to sew even though the selector has been changed.
Feb 16, 2015 | Bernina Sewing Machines
Poor stitch quality
Tensions. Check tensions by pulling on bobbin thread and top thread separately. Check top thread tension with presser foot up and down. Also make sure feed dogs are feeding straight. Manually feed a sheet of paper through the machine to check feed dogs.
Feb 18, 2014 | Husqvarna Sewing Machines
Material won't feed through on kenmore 17600 sewing machine
Take out the material, take off the foot and needle. Stick your finger on the feed dogs and hand turn the hand wheel like sewing. Does the feed dog come slightly above the surface of the needle plate? If it does.... tighten the presser foot tension.
If it doesn't locate the switch that drops the feed dog. Make sure it's in up position.
If neither of those solutions work. Remove the needle plate and see if the feed dog or mechanism that runs it is broken
Good luck
Nov 10, 2012 | Sewing Machines
My stiches are tight and small
Either the stitch length selector is not working, the feed dogs are not working, or the tension is too tight.
Check the manual for your sewing machine for the correct tension setting.
Thread the machine with the presser foot up - always.
Check the settings for the length and see if it changes when you change the setting.
Check the feed dogs to make sure they are engaged/up.
Never use thread for hand quilting or buttons as they both have a coating which can gum up the tension.
Keep the machine clean and lubricated (if this is indicated in your manual - some of the new models require this be done by a service tech).
Feb 23, 2010 | Sewing Machines
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
Dec 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
237 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
