Question about Dryers
Smelly motor motor gives a smell. need to open up the dryer. can't figure out how to open it up to see if something is stuck in the motor. there has been a hole in the lint trap .
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 03, 2012
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
Posted on May 18, 2008
reg501
  • 413 Answers
SOURCE: lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Posted on Jun 14, 2008
lenwest
  • 150 Answers
SOURCE: Dryer won't start and smells like something is burning
Sounds like you have lost your cycle timer or control panel.I would replace it or have it replaced.
let me know
Posted on Feb 17, 2009
  • 659 Answers
SOURCE: My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Posted on Apr 08, 2009
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
Washer agitates but will not spin. Burning smell coming from motor
The water pump could be stuck, or broken so the pulley on the pump is not spinning, while the belt is, which gives you the burning smell. Could also mean the motor is overheating giving you the burning smell. You will have to open the back and observe whats happening while its running. Just keep your hands clear while its working.
Feb 16, 2015 | Kenmore 98702 Stacked Washer/Dryer
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
Avv8000agw slow spin and smelly
First of all check if the motor is hot or there is friction on the drive. Since you had noticed some smell then the best option is to trace the smell which must confirm the case. It could be the motor or possible capacitor or within the power supply or drive output.
Jul 03, 2012 | Admiral AW22 Top Load Washer
Bagged upright panasonic vacuum cleaner motor wavering & smelly
The motor is failing and this causes it to run very hot due to electrical arching, replace the motor.
Apr 05, 2012 | Vacuums
It smells stagnant,opened the flap on the front and smelly water came out,but how do I clean the filter?
Hi from retired Englishman in SW France @ 17:48 Sunday afternoon.
Sorry but I do not know your specific machine but most are very similar!
I will have to assume that the flap to which you refer has the filter behind it because you say- 'opened the flap on the front and smelly water came out'. You should be able to pull the filter out of its 'container' even if it takes some gentle persuasion and patience!.
Also are you absolutely sure that it IS the water itself smelling? If your washer water drain pipe shares a sink's plumbing, it could be that the smell is coming from the sink's u-tube and through the empty pipework. I have had a few problem tickets like that! Plus- normally waste washing water a) smells of the washing powder and /or conditioner and b) would be mostly flushed away.
This is not to say that it isn't the filter with something fairly obnoxious stuck in it!
Good luck,
John C
Feb 06, 2011 | Miele W2240 Front Load Washer
Smells like old smelly socks
this might be coming from the rubber door seal clean it all the way round make sure holes at bottom are not blocked and the rubber door seal is all clean. also clean the draw so there is no power left in there and it is all clean. also a good thing to do is run it though a cleaning cycle with normal detergent at max temperature that the machine can do. hope this helps.
May 20, 2010 | Creda IWD12 Front Load Washer / Dryer
Kenmore 70 series dryer will not start. When starter is depressed there is a sound like something is trying to engage but will not. Then we detect the smell of electrical burning. After a couple of tries...
Hi, It sound's like your dryer motor is cooked. Before you give it the last's rights, it could be something jamming the motor and preventing it from starting...though that usually won't cause them to smoke which would produce the electrical burning smell, just stop via the overload device. Time to unplug the unit and dig into it. If you feel capable, if not call in a pro. I would try to confirm the motor problem first it may be just as worth while to buy a dryer depending on the age & condition of your's. The motor's alone can be quite expensive. Hope that help's move you forward at least. Good luck. Macmarkus :)
Dec 13, 2009 | Kenmore Dryers
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
I'm having the exact same problem verbatium! did you ever figure it out. I already replaced the motor and the belt, but it's still doing the same thing.
Feb 17, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
