Question about Insignia 32" 720p Flat-Panel LCD HDTV
How do I change from cable to antenna input
Just moved, no cable yet. Can't find manual, either lost or packed. I assume change is thru the remote, but I don't know how
    Top Expert:
  • Insignia Master
  • 14,553 Answers
Its in the menu for the set--on screen and is done with the remote---you want to move to antenna/air.
Even if in cable mode it should pick up any active channels 2-13.
Posted on Dec 03, 2012
I lost my antenna input when moving tv and gained an unwanted pc input.
hook up antena,does it really create a problem to have pc show up when you dont use it?
Jul 03, 2015 | Audio Players & Recorders
I had a TV amplifier Channel Master 3042 I need to know how to connect it
This amp can be used with an off-air antenna or a cable box (up to channel 141).
With an antenna: Connect your antenna to the input. Connect the output to the tv's RF (antenna) input (if you're only driving one tv from this amp), or a splitter (if you're driving several tv's).
With a cable box: Connect the feed from the cable company to the amp's input. Connect the output to the input of the cable box.
Nov 13, 2014 | Audio Players & Recorders
No signal stuck on channel 2 with black screen. Model KDL37M3000
Are you connected to a cable or sat box, Are you connected thru antenna input on tv or a/v input. If connect to box thru antenna jack of tv do channel search to pick up ch 3 if box is set to that. If connected to outside antenna still do channel searsh but be sure tv is set to antenna. If connected via av or hdmi the cable or sat box is bad.
Apr 01, 2014 | Sony BRAVIA Televison & Video
Static & no picture from UHF input / Component Video fine
there is sinal interferences from laser products pc mobile transmitters or video games get high quality vcr and cable tv cables move or switch off any video games cd players energy saving lamps or pc and microwaves n motors like pumps change the position of installation of cable and antenna to avoid path of interference
Jul 18, 2013 | Sony KV-36XBR450 36" TV
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
How do I set TV to antenna - Vizio VA26L
The input should be selected as 'TV' to get any on-air transmission. Now the input is selected to Cable. Change it to TV. Refer its user manual for more details.
Aug 04, 2012 | Vizio VA26L 26 in. LCD HDTV
I have a toshiba model 27a44 and have lost the factory remote.is there any way to change from cable to antenna.
If there is a 'menu' button on its front panel, you can enter its menu option, and surf through to select the input window and can change the input you want to. If there is no Menu button, there is no other way. You must have the remote control to select the inputs.
Jul 13, 2012 | Televison & Video
The calble is connected directly to the tv, not through the cable box & when i try to change the channel it says "no signal" at the bottom left corner. Olevia 32" model 532-b12
I assume from your question that you have a cable subscription and that you have the cable plugged into the ANT input via a co-ax cable. The ANT input is for an antenna for over-the air signals. The channel up/down change the internal tuner up/down. For example, if your cable is set to channel 3, it will pull in the cable on channel 3, but then try to pull in over-the-air if you hit channel-up to channel 4.
It seems you need some kind of converter box from your cable company in order to change the cable channels, and then that converter box would plug into either the ANT input (and leave the tuner on 3) or into one of the other inputs like Component, HDMI, SVideo etc.
Feb 13, 2011 | Syntax Olevia 532H 32 in. LCD HDTV
How do i get a picture thru component 2 so i can get 1080i quality. i only get a picture thru component 1.
You would need to unplug the input cables in the TV and move them to component 2 on the back. Assuming your input is at 1080i in the first place (ie, the cable box or digital satelite signal is coming in at the proper resolution). One way to check is to connect an external DVD player to the component 1 input and see if the picture is higher quality than the signal from the Cable/Satelite. Not sure changing to component 2 is going to make a difference. Good luck and let me know what happens!
Nov 04, 2010 | Akai PDP5090 50 in. HDTV Plasma Television
I cannot get vcr to record channels timer goes on and on playback blue screen
I assume it plays back a pre-recorded film with no problem? Check your antenna is connected to the input of the VCR or your cable box. If you have a cable box connected via a scart connector, then select AV channel on the VCR & select the programme from the cable box. If you are using the antenna the go into the set up menu & retune the VCR into your incoming channels & ensure the flylead from the output of the VCR (at the rear of the video next to where the antenna cable is positioned) is connected to the input antenna socket of the TV.
Jul 28, 2009 | RCA Televison & Video
Insignia 32" 720p Flat-Panel LCD HDTV Logo
221 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
