Question about Sharp R-1505 Microwave Oven
LCD Display failing
The LCD display had failed(parts of numbers missing etc.)after 2 years. I replaced the entire board less than a year ago, and the same thing is happening again. Any ideas as to why? The dang board costs almost $100!!
  • Anonymous Nov 27, 2007
    display
  • Anonymous Apr 27, 2008
    We have the same problem with the LCD - after about 2 years, the numbers are not readable. Really a shame, as we haven't had any other problems with the microwave.
  • Sharp Master
  • 9,156 Answers
This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to disassemble it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 08, 2007
SOURCE:
The control display on my microwave is very dim. Is there any way to make it brighter?
If you had mentioned your full model number, we could have looked whether the VFD is available as a separate part in case your model has a VFD display, or whether the whole control board would have to be replaced.
If your model has an LCD type display, it may be weak LEDs or other failing components in the display backlight circuit.
We regularly repair microwave displays for $39.95 nationwide.
It's pretty rare for a microwave to have a display brightness feature.
Let us know if we can help you further.
Nov 16, 2012 | Whirlpool MH2155XP Microwave Oven
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
My microwave has power lights up seems to work but doesnt heat up what could this be?
The magnetron is a common part to fail, but there are other parts that should be considered, if over 7 years the high voltage capacitor and diode, if 7 years or less the inverter board. In most cases cheaper to replace.
Apr 01, 2012 | GE Microwave Ovens
The LCD display is not showing the numbers correctly. It looks like the numbers are missing "lines", like an 8 can look like a 3, the 8 can look like a 0, etc. Any ideas?
It is the control board that needs to be replaced. The LCD display is connected to the board. If this is an above the stove microwave the problem was caused by the steam from boiling water on the stove top. you can prevent it from happening again by using the vent fan consistantly.
Dec 01, 2010 | Sharp R-1511 Microwave Oven
Kenmore Microwave -SE- code
I have the same problem with my microwave and i cant fix it help?
May 10, 2010 | Kenmore Microwave Ovens
Sharp microwave oven LCD display malfunctions
Might or might not work. IT worked for me.
This is a common problem. i havent completly solved it yet but this helps.
Be very careful doing this, There is Voltages with AMPERAGES high enough to boil your blood inside a microwave.
I had mine apart cleaning it. Only one number worked on my display. I wiggled and messed around with the wires in the back of the display. And almost every number in the display works again. Hope this helps.
Nov 29, 2008 | Microwave Ovens
The piece of **** we own is pt# r-1500. In less than a year the lcd display shut down. Now the switch assembly has broken and we have been informed the entire control panel assembly is unavailable. Nice...
Both parts are readily available - you can order them from Martin Microwave Inc.
(toll free 1-877-894-0035).
The lcd / control board / display is Sharp part # CPWBFB075MRU0 and it sells for $79.99
The button assembly is Sharp # JBTN-B122MRF0A and it sells for $13.99
You can also check with www.microwavedisplay.com for a rebuilt board
Sep 10, 2008 | Sharp Microwave Ovens
GE Spacemeker Microwave Oven xl1800
The Control Panel is failing. The Control Panel consists of a Keypad, and a Control PC (Printed Citcuit) Board. You can replace it as a complete unit. Not Cheap!!
Good Luck!
Feb 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LCD display missing part of numerals
Yes, we repair these displays for $32.50 with a one-year guarantee. Repair Clinic charges $169.35 for the display board assembly. Tritronics (our supplier) sells the assembly with display (part # DPWBFC167WRKZ) for $107.07. On the rare occasions when we actually replace that type of board for our customer (at our cost of only $73.33) we also perform our proprietary fixes on it. We do that so the new display does not also fail in a few months, or even right out of the box! That actually happens!
Oct 18, 2006 | Sharp R-530ES Microwave Oven
Microwave
I wiggled the ribbon cable between the control board and the intermediate circut board. The LCD came back for an instant. I am sure it is this ribbon cable. It looks like it is held on with adhesive. How can it be impossible to repair if people are offering to do it less than 40.00 dollars to fix it? Someone must be selling a replacement ribbon cable that will work.
Mar 20, 2006 | Sharp R-1501 Microwave Oven
Microwave Ovens Logo
248 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
