Neptune washer show PF and clicks off, door unlocks, and won't restart. House power is fine and the dryer works.
  • 15,935 Answers
PF = Power Failure.
Unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
What causes maytag neptune dryer has pf error? My dryer worked in air fluff but not sensor or timer mode. Now it will not work at all. the lights on the control panel just blink . What could be the cause..
Pf shows a power failure hols the stop clear button and it should work again.As for your other problems I will more details such as a model number Gas or Electric dryer and example of the problem in detail
Aug 05, 2014 | Maytag Neptune MDE5500AY Electric Dryer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune do code - makes buzing noise when start button pushed - then stops & do code shows - door will not open - also codes pf & po show up
My husband read the book - took the soap dispenser off & did something with a little cord - washer works fine now.
Dec 27, 2009 | Maytag Neptune Washer
Won't run, shows code PF
Well the code pf means power failure, check your cord and see if it connected ok. make sure you didn't blow a breaker in your powerbox.
Apr 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My neptune front loading washer is showing PF, but I did not lose power in the house , and now it will not restart and it was part way through its cycle.
Unplug the unit and let it set for a minute. Once plugged back in start the load from a new cycle, not in the middle of current cycle. If that dosen't work you have a short in the main power board.
Apr 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Neptune washer shows PF yet house power is fine and the dryer works.
Try disconnecting the machine from the power supply, wait for 15 mins and then switch on again, the problem should then solve.
Else the problem might be with the power lines to machine or a damaged control board or a vent damage.please do post further comments if the problem persists.I would be glad to advice on this.all the best.
Jan 11, 2009 | Washing Machines
Maytag Neptune Electric Dryer
pf = power failure
do= door open
the dryer is tripping the breaker because your house wiring is probly not up to snuff, or you have a bad breaker. nothing you are saying sounds like a dryer problem, but could be a big issue with house (could be very bad, could cause fire)
May 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
PF display on my maytag neptune
it stands for power failure. i would unplug the machine for 5 or 10 minutes and that should reset the micro computer.
Mar 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
