Question about Brother LS-2125 Mechanical Sewing Machine
Needle is not moving up or down , the machine is frozen , but it will spool the small bobbins just when you pop it back to stich i wont work
  • Brother Master
  • 1,564 Answers
Sounds like your bobbin winder switch mechanism is faulty. Take it in for repair.
Posted on Dec 04, 2012
  • 323 Answers
SOURCE: The fabric doesn't move forward.
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
sewman7
Posted on Jun 12, 2008
  • 3 Answers
SOURCE: My Brother 270D Starts out
Yes I fixed it and for $14.99 I'll share the solution with you
Posted on Jul 27, 2008
SOURCE: Sewing machine not making stiches
At first, my machine was getting all tangled under the fabric and then would stop working because it was tangled in the bobbin area. Now the bobbin area is staying clear but there are no stiches being made. I have no idea what to do. melissashulga@yahoo.com
Posted on Sep 17, 2008
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Australian S
  • 46 Answers
SOURCE: BOBBIN PROBLEM
Firstly check that you have the correct bobbin for your machine, there are many bobbins that will fit in the bobbin case and sew ok, but the hole in the centre is what matters. If you do not have an original try putting the bobbin on the winder spindle with a small piece of paper inside the centre of the bobbin so it is tight on the shaft.
If that does not work it usually means the winder rubber on the bottom of the cover is worn or stuck, this part often looks like a large O Ring.
Posted on Jul 02, 2009
Lervia sewng machine. material wont feed through. Dogs are up but material just wont move through. needle moving freely.
Hm, could be several things. If stitches are not being formed, it could be a timing issue (the needle does not arrive at the bobbin at the correct time). Did the machine recently hit a pin or something hard? That will knock a machine out of time. There could also be a broken piece stuck that is preventing the feed dogs from operating. Thoroughly clean the machine around the bobbin area and feed dogs.
Jul 28, 2016 | Sewing Machines
Bobbin won't wind/fill. Post does not spin
Pop an empty bobbin on the thread spool. You need to disengage the motor from the presser foot so that the motor no longer makes the presser foot go up and down, but sends the power to wind a bobbin on the thread spool. Check with your machine's manual, but this is usually done be either pushing in, or popping out a button on the hand wheel. Begin a new thread on the bobbin following the directions either from your manual or as printed on the machine. On my Bernina, I have to push the thread spindle sideways to engage the bobbin winder. Use your foot pedal now and the bobbin will automatically fill up. It should stop when full, then you reverse your actions. eg: push the thread spool back, pop in the button on your hand wheel, insert the bobbin (check with your user manual as to clockwise-anticlockwise, and yes it DOES make a difference!) Re-thread your machine (always with the presser foot up) and make a test stich.
I hope this helps and happy sewing.
Mar 27, 2015 | Juki TL-98Q
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
Needle becomes in threaded after 3 stiches
try changing the needle
check for burrs in the bobbin area
check for burrs on the needle plate
try rethreading with a different spool of thread for the top & bobbin
Oct 15, 2012 | Sewing Machines
The needle on my model 1315 Kenmore sewing machine wont go up and down.
try turning the bobbin in the opposite direction & see if that helps
Jul 30, 2012 | Kenmore Sewing Machines
Why does my thread keep breaking and why wont the sewing machine stich?
sometimes the thread can get caught on the spool pin
or on the notch on the thread spool itself
on some machines the thread can come off the thread take up lever
it can also get caught in the top tension area
also check your needle to see if it's bent--roll on flat surface to see if it rolls correctly
there are 3 types of bad needles-bent
blunt--makes a popping sound when going thru fabric
damaged--broke tip
also check your bobbin area for lint or loose threads
check your bobbin to see if it's warped--I've come across some that were warped
check your top thread tension
Sep 24, 2010 | White Sewing 2200 Multi-Tasker
Can't pull thread from spool
The sequence of setting up of thread from spool to needle is not complied to actual setting is one factor to be consider it affect the sequence timing of sewing.Particularly some machine are common in starting up threading.fig. shown a basic flow of thread on red color.It maybe a helpful oneb1934dc.jpg
In addition to this the set up of thread to bobbins winder is also need in right place the thread should be in clockwise rotation when coming out to bobbins casing as shown in fig.76e4431.jpg as you can see when thread was pulled out from bobbins winder is moving counter clockwise.If you try to sew, try cotton fabric and set dial to # 3 to 4 and stitch set range to 8 up to 12 depend on layers and thickness,After setting try to sew manually ,turn hand wheel by your hand first,let upper tension catch the lower bobbins tension and arranged thread and insert fabric use hand turning hand wheel several time until stich appear on fabric observed loop thread on lower bobbins on fabric.if accumulation of loop thread on lower adjust upper tension also dial tension gradually until it has a smooth stich appear.
Mar 15, 2009 | White Sewing Mighty Mender WW100...
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Threading machine
The machine is relatively simple to thread. This is what I do and I've had no threading problems. 1. Put thread spool on the spool pin and put spool guard over spool pin to hold spool onto pin. 2. Take thread and put it under the bent tab by the circle tensioner. bring the thread around the right side of the circle tensioner and bring around the front of the circle tensioner thing back to the top hook on the far left side of the machine. 3. Take the thread around the backside of the top hook think until it threads through the flat piece on the left side of it. 4. Bring the thread down through the first (right side) channel and under the plastic piece to the second (left side) channel. 5. Bring the thread up the second channel and around the moving thread holder and past it's flat metal piece to hold it. 6. Tuck the thread around the small wire thread holder below the needle screw. This may take a few passes to catch it. 7. Thread the needle from the front and run the thread between the teeth of the presser foot. 8. Put a bobbin in the bobbin case so that the thread pulls off the bobbin from the left side of the bobbin if you look at it from above. 9. There is a small channel in the bobbin case that is covered by the bobbin tension flat piece. Pull the bobbin thread through this channel and into the empty space where the needle thread will catch. 10. Place the bobbin case into the machine with the little set bobbin arm pointed to the sky so that it fits into the machine without wiggling to the right or the left. 11. Turn the, uhhh brain fart, the hand wheel until the needle comes back up with the bobbin thread hooked over the needle thread. Take a narrow thing, like scissors or a seam ripper and pull both threads until the bobbin thread comes up. Now your machine is threaded. Use these directions with the pictures in the book to get this machine threaded.
Dec 11, 2006 | Euro-Pro Fast and Easy 420 Mechanical...
Brother LS-2125 Mechanical Sewing Machine Logo
42 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
