Question about Kenwood KDC-MP435U CD Player
RCA connection faulty on Kenwood KDC-2020
The RCA connection is faulty on my head unit and as such signal to my amplifier is sporadic at best. I've had a look inside to see if i can solder the connection, but it does not look like i can do anything about it.
I was wondering if anyone knew a little bit more about this unit that could give me some tips on repairing it?
robotek
  • 1512 Answers
SOURCE: Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Posted on Feb 08, 2008
SOURCE: Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Posted on Jun 11, 2008
tech48
  • 624 Answers
SOURCE: Display on Kenwood Out
I am not sure exactly what solution you are reffering to, but the KDC-MP532U has a problem with the display going out that is the result of heat stressed solder on the main board. The surface mount resistors that are located on the right side near the front of the unit, as you look into it with the display facing you, are the culprits. This is common in about 3 or 4 Kenwood models. These surface mount resistors are on the top of the board, so the board doesn't need to be taken out to fix it. Just the CD mech does. The surface mount resistors just need the solder reflowed, an easy enough job if you know how to solder. They are all lined up connected to each other, I don't remember the reference numbers, but if you can recognize what a surface mount resistor looks like, you should be able to find them very easy.
Thanks for the compliment on the other post, it is appreciated. A good rating would also be appreciated.
Thanks and good luck,
Dave
Posted on Jun 30, 2008
SOURCE: Kenwood KDC-Mp438U security code
Answer for Your trouble on http://www.fixya.com/support/t1354659-unlock_code
Posted on Dec 20, 2008
  • 85 Answers
SOURCE: Faulty RCA rear out on KDC 2020
There will still be a place where the phono sockets are soldered usually underneath them ,and earth to case,desolder original solder joints and resolder with new solder,of course check your cabling first ...
Posted on Jan 15, 2009
Kenwood kdc x597 no sound through the rca conection to my amplifier
Make sure RCA is on threw head unit,
2.make sure you have good cables
3.most ken units have 2 sets of RCA
hook ups one is for cd/changer the other
is a low pass for amp.
4 you have bad RCA channels send to
kenwood for service
Jun 01, 2014 | Car Audio & Video
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
May 31, 2012 | Kenwood KDC-MP4032 CD Player
Amplifier remote start wire
There are dedicated terminals / connection points for "remote" input and output on both the amplifier and head unit. This info usually figures prominently in the manuals of both products. Without knowing the which brand and model head unit and amplifier you have, the info may be incorrect. In the past, many head units made use of Blue or Blue/ White for a remote signal. It was used to control an external amp or automatic antenna. An example is the image below of the wiring of a Kenwood KDC-3011 head unit:
Check your manuals (or Google model numbers) to find yours.
Dec 01, 2011 | Kenwood Car Audio & Video
How can i conect my amplifier with equalizer
I don't know what equalizer you have but, from the head unit RCA output to the equalizer RCA input and then from the equalizer RCA output to the amplifier RCA input. Hope this helps. Without knowing which EQ you are using thats the best I can do. dreamsystems.
Feb 16, 2011 | Kenwood KAC-8401 Car Audio Amplifier
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
Jan 14, 2009 | Kenwood Audio Players & Recorders
I have an KDC-MP435U receiver with 160w kenwood speakers. can you please advise for the the best speakers for this model? can I add a subwoofer? Please advise how can I improve my car sound. I'm using this...
Yes you can add a subwoofer. you will need an amplifier and feed the signal to the amp with your subwooder output rca jacks on the back of the radio. this will give you control over the sub.
Jan 03, 2009 | Kenwood KDC-MP435U CD Player
Kenwood KDC-X590 CD Player
what do you mean by one set is a hard wire and other is an rca jack?the hard wires go to the speakers and the rca is wired to an amplifier of some sort which is wired off to more speakers or subwoofer(s)
Aug 12, 2008 | Kenwood KDC-X590 CD Player
I just bought a KDC MP-235 to put in a 95 camaro with bose amplified speakers. I ordered a amplifier intergration component to reduce the output of the 50 watt per channel head unit as to have better...
Yes, the Kenwood KDC MP-235 has two (2) line level outputs (RCA types red & white). However, these outputs internally passed through an electronic crossover/filter making them appropriate for subwoofer amps only.
If your unit is an MP-235CR, then the same outputs would be for the rear amp (not subs) and are full range (unfiltered).
If indeed your unit is an MP-235 and if I may make a suggestion, still connect the Kenwood to four (4) speakers. It would not be technically correct to leave the internal amps operating with no load (speakers) connected. Additionally, you would be getting 200 watts (4 X 50) more to your system (since it is already there).
If your Bose amp & speaker are subs, then no issue, however if the Bose is for a full range of speakers, then only the woofer part would be working efficiently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | Kenwood Car Audio & Video
Kenwood KDC-MP435U CD Player Logo
104 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
