Question about Dell Inspiron 1750 Laptop
Dell Inspiron 1750 will still not start up after new motherboard has been fitted
Hi. I'm trying to fix a Dell Inspiron 1750 laptop for a friend of mine. The PC repair shop said it was the motherboard and would charge 200 to repair so I found a new motherboard for 69. Before the refitting the motherboard, the laptop would begin booting i.e. the CPU fan would start going and the white light on the front turns on, but the laptop fails to begin POST and nothing is shown on screen. My friend did say that they had been using the laptop without battery fitted for some time without issue. However after fitting new motherboard, the same issue is occurring. Any help would be greatly appreciated
    New Friend:
    Problem Solver:
  • 5 Answers
I think the new motherboard dosen't matchmaking with your Laptop .So , you should change it
Posted on Dec 03, 2012
  • Jack Barritt Dec 03, 2012
    Well the motherboard is exactly the same make and model as the old one so that shouldn't make any difference. I did notice that there is a separate power jack daughter card that attaches to the main board. Could it be this that is causing the problem?
  • 5 Answers
SOURCE: Dell Inspiron 2200 loose DC power pin connector
hi, the power jack must be removed by a strip out and de solder of jack and a new one fitted. I was lucky a guy took £30 for the job.
Posted on Feb 17, 2008
vincebeach
  • 37 Answers
SOURCE: Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Posted on Nov 11, 2008
SOURCE: Inspiron 1501 will not power from know good AC adapter.
Hey, i have a solution to this - it involves a cold solder joint on C34 (i believe, i repaired mine a while ago) - but i took pics and stuff. If you need help, feel free to drop me a line at crossan007@gmail.com, or AIM: crossan007
Posted on Mar 03, 2009
foxyreign
  • 52 Answers
SOURCE: dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Posted on Jun 10, 2009
benwabnick
  • 2404 Answers
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Posted on Nov 30, 2009
Cannot reseat my hdd not found?
Hi Robert Clark,
You may try reseating the hard drive by referring the below link which is a user manual for Dell Inspiron 1750:
http://downloads.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1750_service%20manual_en-us.pdf
However, if this doesn't help then please explain the issue with the hard drive then I can check and see what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Apr 08, 2015 | Dell Inspiron 1750 Laptop
I installed a new internal hard drive in my Inspiron 1750 laptop. I am getting a No boot sector on internal hard drive error. How do I get it to boot up and get recognized?
Have you installed the Windows OS on the new HDD? Insert the new Windows OS in the DVD rom drive, shut down, Unplug, remove battery, plug in, at boot the new OS DVD should start and ask Press any key to boot from CD/DVD, tap key.
Feb 03, 2013 | Dell Inspiron 1750 Laptop
What type CMOS battery will fit a 1W766 motherboard
Hello here is the homepage:
http://www.dell.com/support/troubleshooting/us/en/ussoho1/Product/inspiron-8600
You have to order the battery from a dell service center.
It look like this:
But here could be a difference depeding how old the laptop is.
Here is the other type:
The dell dealer should know what right in your case.
Hope this will help you
Dec 03, 2012 | Dell (1W766) Motherboard
The "galaxy of games card classics"will not run/play on my dell 1750 inspiron for some un known reason, can you fix this problem? '
You can run older programs in Windows 7. Here are 2 fixes:
1. Run a Program in Compatibility Mode in Windows 7. This one is easier, so try this one first. It should work.
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
2. Run Windows XP Mode with Virtual PC. This one more complicated because it involves installs and running a virtual system. Use only if you feel comfortable with instructions.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Sep 25, 2012 | Dell Inspiron 1750 Notebook
Reset inspiron 1750 back to factory
try "SYSTEM RESTORE' on your computor it will restore it back to a date specifyed by you.go to the START button and click on CONTROL PANEL then go to SYSTEM RESTORE
Feb 12, 2012 | Dell Inspiron 1750 Laptop
Dell Inspiron 1750 no backlight
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 08, 2011 | Dell Inspiron 1750 Laptop
How to clear the cmos of dell inspiron i can't get pass the password
you have to remove your CMOS battery from motherboard & than you start your laptop,
After that
Fix it as it was & than restart your laptop your CMOS password will be removed after this procedure
thanks
Jan 04, 2011 | Dell Inspiron E1505 Notebook
NVIDIA nForce 790i Ultra SLI on Inspiron 1750
no, it wont. Dell notebooks have proprietary components and configurations, and using another motherboard will not work, it wont fit, it wont interface with the connections, and it wont make you happy. If you want to get a gaming machine, buy an alienware device, or, (if you wanna get out a little cheaper) go to the Dell outlet, and get a refurbished Dell Studio XP. you can get one with a 2200 64 bit dual core CPU, 4 gigs ram, and 320 gig hdd for about $620 after fees etc.
Aug 28, 2009 | Dell Computers & Internet
Dell Inspiron 1750 Laptop Logo
220 people viewed this question
Alun Cox
