Coleman outdoor furnace/AC blower speed too fast
Is there a way to slow down the blower speed on my unit. It seems to run way too fast. I think it should be slower for heat and remain fast for AC. It is probably just a matter of changing a wire, but not sure.
  • 306 Answers
You are right slow for heat and fast for A/C. Here are the blower speeds black is high blue is med. and red is low if you have orange it would be med low. Look on the control board and see what color wire is connected to heat and let me know if you have something other then control board. You can take the wire that is on park and swap them around. ken
Posted on Jan 12, 2009
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Coleman electric furnace
You don't say whether you replaced the blower but that could be the next thing to check
Jul 23, 2013 | Heating & Cooling
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
Loud blower on my Coleman Furnace
Usually a noisy blower motor is a bad bearing. The motors now have oil impregnated bearings and you can't oil them, you have to replace them.
Sep 19, 2012 | Coleman Mobile Modular Home Electric...
My Honeywell AC unit doesn't seem to be working properly. It will not retain a temperature. I set the thermostat to hold a temperature of 70 degrees. Room temp still reads 74 degrees. Something is working,...
The frost on the pipe indicates you have a dirty filter, dirty evaporator coil, Blower not running at the proper speed (to slow) or you are low on refrigerant.
Jun 29, 2010 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Coleman 7900 gas furnace/central ac, was working fine, now blower wont come on, it tries but turns real slow then stops, i took it out and bench tested the motor andit works fine, put it back in the...
Motor run capacitor. If problem is intermittent, try wiggling wires from motor to capacitor to check for broken wires. Motor might seem to work ok with no load on bench but it has no real power. The power to really spin the motor under load comes from the capacitor
Jun 29, 2008 | Coleman Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
239 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
