Question about Hotpoint Ovens
Hotpoint oven makes a loud beeping sound and F-1 flashes
Model no. RK736G0P5BG
serial no. ML6107900
Oven was not on but had been used an hour or so before the problem. beeped continuously and F-1 flashed across the screen. mashed off an it quit momentarily then repeated doing it until I cut off the circuit breaker. This was Saturday night, and it did the same thing Sunday Morning.
706-485-9287
cell 706-473-1825
docjohn174
  • 943 Answers
SOURCE: F1 error on SS Amana Convection wall oven
hi in the amana fault codes it says to replace the clock.its faulty thanks
Posted on Oct 16, 2008
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
SOURCE: Viking Electric oven beeping saying EOCGT v36 premiere poweringup
Sounds like leaving the door open has possibly cooked the controller. I would try a power cycle - power off at fuse for 5 minutes, then reapply power. If this doesn't clear it, you may need a new controller for it.
Posted on Nov 27, 2008
apexappli795
  • 46 Answers
SOURCE: F1 message flashing, annoying beep in the middle of the night
you could have a bad touch pad or ECU which is the main control board.
Posted on Sep 16, 2009
localwonder
  • 6784 Answers
SOURCE: flashing on oven F54 shut off oven at circit
HI. This code is an indication of a shorted upper door latch circuit. This could have be caused by a malfunctioning relay board.
The necessary actions are to gain access to the upper door latch assembly, and test the circuit with a meter. Use the procedure below.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing.
NOTE_ If the upper door latch switch passes the test, simply replace the relay board.
Posted on Jan 02, 2010
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
My hotpoint oven is burning everything so need to know what to replace
If your oven is burning everything, it is getting too hot. Therefore the heater is working but the thing that measures the temperature is not. This is called the thermostat and there will be two types, one for each oven.
Google search for Hotpoint UY46 thermostat, there are plenty of suppliers. Make sure you get the correct one for the oven that is burning.
They are about 20-30 pounds to buy and generally easy to change. Just make sure the power is turned off before working on the oven and be careful of sharp edges as it is easy to get cut when removing panels.
Good luck.
Sep 01, 2014 | Hotpoint UY46 Style Line Stainless Steel...
Cooling fan seems to be making a very loud noise , is it easy to replace
on a scale of 1 to 10 / it's a ( 7 ) / takes about 1 hr . and helper for wall oven . .
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint Openspace Timer problem
no, but can i ask your general opinion of this as thinking of buying one
Apr 07, 2010 | Ovens
Sep 16, 2009 | Amana AOCS3040 Electric Single Oven
My magic chef oven flashes F-5 when we try to turn on the oven!
Hi
Thanks for using FixYa. Error code F5 means Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction.
Turn off the Oven for 2-3 hours, the oven will reset itself. However, if the error still persists then follow the procedure to troubleshoot the error code--
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F5 and listen for the beep.
  • If you get the F5 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F5 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Sep 13, 2009 | Ovens
HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Nov 23, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Oven
Aug 07, 2008 | Ovens
F2 error
what is solution
Dec 08, 2007 | Ovens
Ovens Logo
29 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
