Question about Westinghouse Vacuums
How do i get the belt back on my Wwh50
How do i reassemble my vacum? i took it apart to clean it.
5 Suggested Answers
  • 175 Answers
SOURCE: How to reassemble vacuum elbow tube with plastic insert?
If the plastic insert has come off then that is not normal. It should be all one piece to the hose. You might have a hose problem that needs replacing.
Posted on Nov 30, 2009
Dysonteam
  • 167 Answers
SOURCE: I cleaned the roller on my Dyson DC 07, and after
Hi its Darran at Dyson.
Your machine is designed to make this ratchet noise if the brush bar is obstructed. We would recommend checking the brush bar and soleplate area and removing any blockages or hairs/threads that are wrapped around the brush bar.
Full details on these checks can be found in our Support section online at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 16, 2010
heatman101
  • 43501 Answers
SOURCE: can't reassemble top of carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fggh
Posted on Sep 30, 2010
  • 250 Answers
SOURCE: Hello, my names Travis. I
Look for grooves on the motor shaft and on the brush shaft.
Posted on Mar 20, 2011
I have a Shark navigator upright vacum NV22L 31. When I vacum the roller stops and starts spinning on and off. What could be the problem?
Well apart from it not being a Dyson? :>)
Usually two things.
The beater brush is not spinning freely due to hair and fluff at the bearing ends. Remove the brush and clean them.
Due to age, the belt has stretched or worn thin, or both. Change the belt every year.
Oct 10, 2017 | Shark Vacuums
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt issue
Check the switch to the brush bar it might not be in the right position it needs to be in to run or not run should be in a little slot that turns it on and off
Apr 18, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Eureka TRUE HEPA Whirlwind Bagless same problem seems...roller just stopped...took everything apart and turned it on just in time to see belt melt...I was able to get the end caps off both sides at first...
If you are able to remove one end cap, the brush roller shaft can be removed and the other bearing is exposed for examination and removal of the hair that probably is clogging it. After cleaning and reassembly the brush roller should rotate freely. Clean any burned belt residue from the motor shaft and install a new Eureka belt.
Aug 02, 2013 | Eureka 2961AVZ Bagless Upright Vacuum
I cleaned the roller on my Dyson DC 07, and after reassembly, it makes a sound like the belt is being chewed. I took it apart a couple times, goes back together fine, but still makes the noise
Kind regards
Darran
Apr 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Water comes out the accessory hose but not the floor cleaner
I had the same problem and the heater ports were clogged. I took apart the top unit and cleaned the ports with miniature bottle brushes used to clean spray painting equipment (purchased at Harbor Freight for $4). Reassembled and the unit worked fine.
Feb 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
Can't reassemble top of carpet cleaner
heatman101
fggh
Jul 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Rainbow will not come back on
Bad idea.... I think the foam got through the separator and into the fan system. When it dried it hardened and now it need to be taken apart and cleaned.
Turn it on for less than 1 sec and if you hear motor making humming sound - it is ALIVE and cleaning (maybe new fan blades too) may be all that it needs. If no sound at all it may be KAPUT. You must have smelled something burning when you turned on and it did not work.
for D4 and SE models - When cleaning I would recommend to replace bearings as they are not that expensive and if you took it apart - maybe a good idea to replace them. Also you probably will need a new gasket as when taking old one off (it is glued) it may rip apart.
For e-series - you will need a new HEPA filter.
(parts HERE)
For Parts see
Mar 03, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Push the reset button
Sounds like a problem I had. However, I took the vacum head apart were the belt is to get to the switch that was sticking. the model # on this part is:
Mel Rain/littel fuse
742332
11200000-04
HOLD 2.0 A.
125 V.D.C. / A.C. 60Hz
I took the two connectors of and carfully removed the part. After removal I took apart with a small flathead screwdriver and reset but this is a quick fix and my vacuum begin to work again!
Aug 03, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
63 people viewed this question
Top Westinghouse Vacuums Experts
Kevin Getz
Kevin Getz
Tom Chichester
Are you a Westinghouse Vacuum Expert? Answer questions, earn points and help others
