Question about Samsung Dart T499
3g won't trun on
  • Samsung Master
  • 14,641 Answers
My Dear Please try it;
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Dec 03, 2012
Camera won't trun on
It is either a battery contact problem or it is something more serious with the camera.
Jan 27, 2013 | Panasonic Lumix DMC-TZ3 Digital Camera
White screen the phone won't turn off
Here is the link that might be useful, hope it helps: http://phaktor7.wordpress.com/2008/12/17/iphone-3g-white-screen-of-death-solution/
Dec 25, 2012 | Apple iPhone 3G
Engine won't turn over
This is most likely the battery, sometimes you can have enough power for dome lights and radio, but not enough "Cranking Amps" to start the vehicle. Charge it, or take it to an Auto zone or something. They will charge it and test it for free.
Feb 21, 2012 | 2002 Pontiac Grand Am
Engine wont turn over on my gv 2006
The 1st thing i need to do is clarify what you mean by "won't trun over" do you mean the starter motor spins the engine and it will not fire up or that the starter doesn't trun the engine over? If the starter doesn't turn the engine over do you hear a clicking coming from the starter solenoid when this happens? If so replace the starter solenoid the heavy electrical contacts are burned.
Dec 28, 2011 | 2006 Suzuki Grand Vitara
My 3g screen is not responsive after changing the screen/digitizer/frame. Powers up, but locked slider won't respond.
I would verify that all of the proper connections are in place. Here's a video for clarification:http://www.youtube.com/watch?v=4mboB8p-sdw
Dec 11, 2011 | Apple iPhone 3G
Can't connect a nexxus bluetooth headset to 3 Skypephone 3G, what do i do? the seller said the phone is missing a software or something
skypephone isn't iphone. There not the same product. So most i-devices or I supported devices won't work with a generic iphone
Nov 08, 2011 | Apple iPhone 3G
My iphone 3gs won't make phone calls, it keeps saying no service, then searching, then says it has some service but whenever i try to make a call it doesn't go through
It sounds like your phone has been locked,
This download has all the latest updates and all the latest upgrades .
2g, 3g, 3GS, up to 4.2.1
It will unlock iphones that were locked due to an update in itunes.
You will be free to use ANY SIMS card from ANY network.
Keep it on your computer and use it as many times as you want to. (friends & family)
Get FREE Apps, games, customized keyboards, ringtones, themes, toys, utilities, wallpapers, backgrounds, all for FREE !!!
Have your iphone unlocked in minutes not days. (about 5 min.)
It's very easy to use and there is a 30 day 100% money back guarantee !!!
http://tinyurl.com/Debbie38133
Aug 05, 2011 | Apple iPhone 3G
Is it possible to reflash my SGH a867, so i can change the 3g 850mhz 1900mhz set by at&t, to 900mhz too 2100mhz
Reflashing won't do you any good. It's not a software issue that controls the bands, but rather the hardware. Without the hardware in the phone to communicate on those bands it won't work.
Jun 10, 2011 | Samsung Eternity SGHA867 3G NEW
Campbell Hausfeld 13 gal air copressor, when I trun it on it won't build up max pressure and won't shut-off One of the gauges reads 40 PSI the other reads 60 PSI.
Your problem is most likely because of damage to the valve plate or piston & cylinder. If one or both of these are not working properly you'll get partial pressure and the unit won't turn off because the tank never comes up to full pressure. Things to check for are damage to the reeds on the valve plate, they could be bent from overheating or broken from use or wear or damage to the piston seal which can cause damage to the cylinder. If any of these aren't sealing properly the air pressure will come up to a point where the air leaks out faster than it goes into the tank. Without your particular model number I don't know which parts to recommend but if you contact Campbell Hausfeld they'll help you get the right parts.
May 12, 2011 | Campbell Hausfeld 13 - Gallon Air...
Samsung Dart T499 Logo
152 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
