Question about Acer Aspire 5570-4820 Notebook
Code p1137 car is not turning over, and electrical system is acting up
  • Acer Master
  • 7,627 Answers
Wrong category
Posted on Dec 03, 2012
Code p1137 2002 pontiac sunfire
Change O2 Sensor number 2 which is down stream after the cat. Low voltage during power enrichment sensor 2
Jun 03, 2014 | 2002 Pontiac Sunfire
Obd 2 reads p1137 on my 2000 beetle. Blend to rich what do ido
Its your oxygen sensor. But some car's has more than one. Could be on bunk 1 side or bunk 2. Usually, codes will tell you like p1137 then definition. Bunk 1 means before the catalytic converter, bunk 2 means after. All car manufacturer has different location on this sensors defending on engine size. Good luck.
Nov 16, 2013 | Cars & Trucks
How do you delete code p1137 from 2001 Chevy cavalier ?
Four digit codes are brand specific. Code 1137 for a GM product means the O2 sensor mounted after the catalytic converter is producing a low signal.
The sensor and wiring would need to be checked.
Jun 23, 2013 | Cars & Trucks
I have a p1137 code fuel air metering on a 2002 chevy cavalier where is this located
Air/fuel metering usually referes to O2 sensors and/or MAF sensor. In this case it referes to heated O2 sensor bank #1 snsr2. This Can be found on the exhaust system on the rear of the cat or after the Cat. Conv.
Mar 10, 2012 | Chevrolet Cavalier Cars & Trucks
Idles rough and low intermittently. Stalls occaisionally. Error code P1137 pulled off of the computer. 2001 Alero, 2.4L Automatic trans
P1137 is HO2S Bank 1 Sensor 2 Lean Or Low Voltage. Oxygen sensor is reading a "lean condition". This code probably is stored from the rough and low idling. So it sounds like you maybe having other issues causing this P1137 code to come up. For lean conditions read this:
1. Vacuum leaks - check for failed or loose vacuum lines, leaking intake gaskets, intake air tubes loose or any other source of un-metered air leaks (leaks after the Mass Air Flow Sensor)
2. Restricted fuel filter or bent/pinched fuel system lines
3. Incorrect input from other sensors, such as the Mass Air Flow Sensor/cam or crank sensors, which may not always drop a separate code
4. Engine misfire ? Yes I know this one may seem weird. You might think that if there is a misfire then you will have all that unburned fuel and it should read rich; right? Well the O2 sensors read only oxygen content in the exhaust, so if you have all that unburned fuel from incomplete combustion then, you guessed it, you also have all that unburned oxygen. High O2 content in exhaust equals a lean reading!
Sep 07, 2011 | Oldsmobile Alero Cars & Trucks
Hi,i have a 2000 beetle 1.8 turbo,has p1137 error code.Iput new precat 02 sensor,new camshaft pos,sensor and still same code,do you think MAF sensor its bad if i replaced 6 months ago?.,what is my next...
IF you're diagnosing purely off a P-Code of 1137 then you're looking at the following areas.
  • Check Mass Air Flow (MAF) Sensor
  • Check Fuel Pressure Regulator
  • Check Fuel Injector(s)
  • Check Oxygen Sensor Control
    • Check Oxygen Sensor(s)
  • Check Evaporative Emission (EVAP) System
I own a VW and know how hard they can be of you start "chasing a problem". Are you using a VAG.COM cable and software to check your codes? MORE IMPORTANTLY after you changed your parts, does it START? If it's starting/running and you're just trying to get rid of the code, you need to clear it. However, if you're not starting/running then you need to clear it and check for next codes that the ECU is throwing.
Mar 08, 2011 | Volkswagen Beetle Cars & Trucks
Engine light on. diag tester code P1137 undefined code what should i do next?
P1137 relates to a blip in the fuel trim where as the max threshold was reached. I have simply deleted the code in the past and it was ok, never came back. However if it does come back you will need to find the cause. This is most likely a MAP or MAFS fault.
Regards
Lloyd Six
Jul 12, 2010 | 2000 Chevrolet Cavalier
Hello my Audi A4 has several cades coming up P1479 something to do with the brake boost vaccum system P0322 engine rpm sensor P1128 bank 1 system too lean P1137 Bank 1 system too rich. Are these faults...
Yes If you have a vacuum leak it will pop the oxygen sensor codes to rich/ to lean. the rpm code is some thing different, it could be as simple as you over revving the car.
Jun 14, 2010 | Cars & Trucks
Acer Aspire 5570-4820 Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
