Question about Sony KP-53V45 53" Rear Projection Television
SONY manual de servicio KP-53V45 manual de reparaciones
Hola nesecito Todos a los planos de reparacion de mi ayuda TV! no prende (no enciende) (NO power) Help !
    Top Expert:
  • Sony Master
  • 14,553 Answers
Google the model number with "service manual"
Posted on Dec 03, 2012
SOURCE: necesito ayuda ... en espa?ol
quiero saver como conectar mi camara labtec en mi computador HP
Posted on Jun 30, 2008
ladywinn
  • 5138 Answers
SOURCE: Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Posted on Dec 03, 2008
  • 36 Answers
SOURCE: Sony KP 61U80 projection tv. Power light is on but no picture.
Based on your problem it appears it might be a dead bulb, it certainly matches the syndrome.
Posted on Jul 24, 2009
ladywinn
  • 5138 Answers
SOURCE: How do I find out
Go to retrevo.com and type in your model# they have owners Manuals you can read online or print them out.
Posted on Oct 14, 2010
Kensolutions
  • 455 Answers
SOURCE: have a mod # kp-53v45
Please open the manual of the KP-53V45 TV by clicking here. To program the channels in the TV, make sure that the cable is connected to the TV using the Coaxial VHF-UHF cable. Select the Auto Program option to program the channels in the TV. Press the MENU button select SETUP MENU and then select AUTO PROGRAM option to scan all the channels in the TV.
Thanks for contacting FixYa.
Posted on Jul 17, 2011
Nesecito urgente el diagrama electronico del Mackie SWA1501
  • Espero que esto ayude y gracias por usar FixYa
Saludos, Tony
Aug 26, 2011 | Mackie SWA1501 Subwoofer
Hola nesecito los codigos para programar mi aux marca sony .. tengo control dish
Hola mi nombre es Mayra Diaz con DISH Network. Sera un placer ayudarle y proveerle la informaci?n que necesita para programar un control de DISH Network a su televisor Sharp. Hay ciertos c?digos que se pueden integrar al control que le permiten funcionar con la televisor, unos de los c?digos serian los siguientes: 500, 758, 590, 640, 690 y el 090. El procesamiento a integrarlos es el siguiente: Presione el bot?n de T.V localizado en la parte de arriba del control hasta que se prendan los dem?s en rojo una vez esto suceda ingrese uno de los c?digos seguido por el signo de numero por ejemplo (#700). El bot?n de T.V deber? iluminarse 3 veces en rojo si el c?digo es compatible. Despu?s de esto puede intentar usar el control con su T.V. Espero esto le sirva de ayuda si tiene preguntas adicionales o necesita ayuda puede contactarme directa mente a mi correo electr?nico
Apr 03, 2011 | DISH Network IR Remote Control
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
Bunas dias , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes...
Que tal yo tambien tengo el mismo problema con mi tv insignia de 32¨ , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes estan presentes a la salida de la fuente, cambie todos los filtros de la fuente pero nada, gracias por su ayuda.
mi corre es carlitoswwway@hotmail.com
Nov 30, 2010 | Insignia IS-LCDTV32 32 in. Television
Necesito ayuda urgente si ustedes son tan amables de ayudarme se los voy agredecer yo necesito el service manual porque compre 10 dictaphone 2750 desktop tengo problema con tres de ellos porque el motor se...
Hola Soy Tecnico en servicio de SONY y Dictaphone Y estas en lo correcto el modelo de Dictaphone 2750 Stadard cassette uno de sus problemas es que si la unidad queda con el cassette dentro y sin seleccionar auto encendido el motor queda funcionando asi que se muere mas rapido la verdad es que necesitas remplazar el motor y el motor solo tine dos cables asi que no es mayor problema el remplazarlo te puedo dar un correo para que solicites el motor normalmente esta compania no vende partes solo da el servicio de reparacion de las maquinas pero puedes decirles que Javier te recomendo para comprar estos motores que nececitas, despues de remplazarlo tus maquinas quedaran bien otraves email to service@tvps.com
Nov 30, 2009 | Dictaphone 2750 Desktop Cassette...
Necesito todos los drivers asignados para el Acer TravelMate 3010 (3012WTMi)
https://www.acer.com/ac/en/US/content/support for drivers and support
Mar 07, 2017 | Acer Cameras
Open Questions:
Televison & Video Logo
159 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
