Question about Toshiba RD-XS32 DVD Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ? I have the same problem for months... I just can't use my RD-XS32 recorder because of my remote stuck on DR -off each time Ipress a button. The up and down buttons solution won't work with me... Any other idea ?... thanks
Got the same problem today. I found the solution online on the installation guide. You need to push the two channel changing buttons on the recorder at the same time for 3 seconds.
Posted on Jun 04, 2009
U99 error code
The remote isnot going to eject the the disc, You have to press the eject button on the unit, To get the disc to eject,
Nov 26, 2012 | Panasonic Dmr-eh67e Pal Dvd Recorder With...
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
L.S. How to reset Panasonic DMR-EH55 DVD Recorder / HDD Recorder to factory settings?
You can either go into menu (pressing 'FUNCTIONS' button on remote) and look for 'RESTORE DEFAULT SETTINGS' or similar heading, or you can (while unit is on) on the front of the unit (not the remote) press CH UP and CH DOWN buttons together for 5 seconds - the unit will switch to standby. Give either one a try. (refer to page 60 onwards in your user manual - these pages detail 'settings').
If you cannot find your manual, it is available for download (free) - http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Operating-Instructions/model.DMR-EH55S.O#ts
I hope this helps in some small way. Thanks for asking FixYa!
Feb 12, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba RD-85DTSB recorder remote control wont work, getting DR-Off when pressing any buttons?????
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Oct 01, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
We have a Panasonic DMR-EH50 DVD player/recorder. We recently moved house and following the move, the FUNCTIONS button on the remote no longer works. Everything else on the remote does. I've tried...
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Apr 04, 2010 | Panasonic DMR-EH50 DVD Recorder
Dvd recorder dmr eh-55 remote will not change from code 2 to code 1. i have followed instructions to no avail. pls help
≥The remote control and main unit are using different codes. Change the code on
the remote control.
Press and hold [OK] and the indicated number button at the same time for more than 5 seconds.
Sep 22, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Toshiba RD-XS34
Hold down the easy-navi button and number 1 on the remote.
Sep 13, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba RD-XS32 DVD Recorder Logo
481 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
