Question about GE Profile WPRE6100G Top Load Washer
My agitator quit working and i took the agitator
I took the agitator off and the shaft under the nut free spins. what would fix this? and how?
  • 700 Answers
Theres a belt under neith the unit that is activete whats called wig wags. they activate and that is what activaes itt. v
Posted on Jan 11, 2009
Washer not agitating, fills, spins and drains but wont agitate. grease at bottom of shaft above belt puley
Check the splines on the drum. Take the cap off and remove the lock for the nut, take the nut off and you can pull the whole agitator out of the drum. Look at the splines on the shaft and in the agitator. Make sure they are not worn down to nothing.
Oct 14, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have a kenmore washer machine 23832-100 that has stopped working. I would like to know how to remove the agitator so that i can examine the machine
I had the same problem. Well, possibly...my washer worked, but quit agitating. If that is your problem, then there are a couple of possible ways to remove the agitator. On one model, the cap on top could be removed by unlocking tabs with a screwdriver, then a bolt unscrewed it to free it from the shaft. In another model, the agitator simply had to be pried (and pried, and pried) off. Turned out in both cases that the inside of the agitator was worn badly enough to let the shaft spin free if under any kind of load. Both times, I was able to go to a local appliance repair shop and used appliance dealer and get a new agitator for around $10.
Hope this helps you out!!
Aug 09, 2010 | Washing Machines
Ge whdsr315 top load washer will spin but not agitate unless pushing down on agitator
Sounds like the nut that holds the agitator on to the shaft is not tightend down or the agitator is not fully "locked" into place on the shaft.
Jun 16, 2009 | General Electric WHDSR316G Top Load Washer
Maytag top load clothes washer tub spins hard
Hi, You can unsnap the plastic splash ring and see if something is between the tubs. The inner tub turns rather hard anyways. The agitator might have a 1/4" screws in the side of it to hold it onto the shaft of the transmission. If not, just pull the agitator up real hard.
Under the agitator is a spanner nut that holds the inner tub in place. I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Maytag LAT3600A Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
Complete loss of boost
Yup your turbo is toast, ive had the same thing happen on a nissan skyline. The smoke you describe is the oil escaping from the turbo core and burning off in the dump pipe.Even though you managed to get the nut back on the compressor wheel the damage to your exhaust wheel, bearings and shaft is already done, chances are you'l be missing a few fins in the exhaust wheel to say the least, it would've propelled itself in the exhuast housing probably spinning at atleast 25,000 rpm.The turbo in the gt4 is a stong unit, just how much boost were you running? :)
Jan 11, 2009 | 1996 Toyota Celica
Spin cycle...
Sounds like the spin tub mounting block is stripped to me. Remove agitator. Remove spanner nut holding spin tub to basket drive. The block is the aluminum piece joining the basket drive shaft. The aluminum block has two square indentions that sit down on two tabs formed on the basket drive shaft. The soft metal wears out on the block and the drive shaft isnt attached to the spin tub anymore. An easy way to test is remove agitator and put in spin. See if shaft spins but not tub spin.Let me know what you find
Dec 12, 2007 | Kenmore 24032\24036 Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
73 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
