Question about Maytag MGR6875BK Gas Kitchen Range
On my Maytag Gemini MGR6875 the flames on the burners are too high on high and go out on low.
We just changed from LP gas to Natural gas. we changed the orfices on the burners and the oven. We have also changed the burners and the ignitors and one of the gas valves for one of the burners.
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 650 Answers
If you haven't changed the stove regulator to natural gas this could be your problem. If you are not comfortable with making this adjustment pleaee check with your gas company or a licensed appliance service person to do the work it should take just a few minutes.
Posted on Dec 03, 2012
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Swithed to LP
did you change the ovens burner orfice?if not theres your problem.
Posted on Dec 25, 2007
buffalonyman
  • 1865 Answers
SOURCE: I have a Maytag Gemini double oven with a gas
18" is standard
Posted on Apr 16, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a maytag gemini
Hi
The issue is with the tubing or the manifold that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 22, 2011
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Sep 15, 2009 | Kenmore Kitchen Ranges
Flame is too high even when on low
The pressure regulator and the orifice for the burners has got to be changed to run LP
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 14, 2009 | Whirlpool SF367 Gas Kitchen Range
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 | Ovens
Flames in oven are WAY too high! Having trouble lowering them.
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Jul 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Maytag MGR6875BK Gas Kitchen Range Logo
93 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
