Question about GE GTDL200EMWW 27" Front-Load Electric Dryer with 7.0 cu. ft. Capacity, 5 Dry Cycles, 4 Heat Selections, Dewrinkle/Delicates Cycle, Quick Fluff and Auto Dry
Dryer will not start
The starter switch is getting power, but it seems very stiff.
    Top Expert:
  • GE Master
  • 9,472 Answers
I would replace the start switch. Here is the part to order.
Posted on Dec 03, 2012
1990 HONDA ACCORD WON'T TURN OVER TO START BUT IT WILL ROLL START. I HAVE CHANGED THE ALTERNATOR AND TESTED THE IGNITION SWITCH STARTER RELAY SEEMS FINE CLUTCH SWITCH SEEMS FINE MAIN RELAY IS FINE
About the only thing you didn't mention was the starter itself. You could have it tested. But before that, try to see if you have power on the small wire to starter solenoid on the starter, when key is held in cranking position. Pull the small wire off and check for power with a multimeter or a testlight while someone holds the key in crank. This is the signal wire from ignition switch that closes the elec. contacts inside solenoid so the starter gets full power from the battery to spin. (This wire also is in the circuit with the clutch switch and the starter relay.) If you have power on this wire in crank, it is very likely the starter is bad. If there is no power, check that circuit out. It is losing power somewhere from switch to starter solenoid. Good luck.
Jul 06, 2012 | 1990 Honda Accord
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
heatman101
Jun 27, 2011 | Dryers
Starter motors good but wont turn over my1982 lincoln continental
When you say the starter motor runs, do you mean it runs fast but does not turn the engine, in that case it may be something to do with starter not engaging the ring gear.
If when the starter runs it turns the engine slowly then it could be starter is not getting enough power.
The reasons for starter motor not getting enough power can be, a bad battery, loose battery connector, stiff engine or a bad starter solenoid.
To check a bad battery, turn your head lights on and when you try to crank the engine, if the light go dim, you have a bad battery or a bad battery connection. If the lights are not affected you may have a stiff engine.
Mar 02, 2010 | 1994 Chevrolet Camaro
My Inglis dryer will not start when the start button is pressed. I've checked the starter switch with a continuity tester by touching one probe to CO (black) and another probe to NO (white)--it doesn't...
No. Judging from what you are saying, the switch seems to be making. First, I would check the thermal fuse. It is usually located just inside the back of the dryer, mounted on or near the exhaust duct. It's about an inch long and can be checked for continuity. If it has none, it is bad. Second, you could look at a faulty door switch. It is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or the front of the dryer to access the switch. You can test it the same way you tested the start switch. Hang in there!! You'll find the problem. Hope this helped and best wishes.
Jul 26, 2009 | Dryers
1998 4X4 Blazer stiff brake pedal and car will
seems to be the starter---car is being towed to the shop--thanks for you help
May 04, 2009 | 1998 Chevrolet K1500
Starter problems
you need to check and see if you have 12volts at the relay and if you have 12volts at the wire from the switch on the relay. if you are getting power to the wire from the switch then you may have a bad starter relay.
Apr 04, 2009 | 2004 Suzuki LS 650 Savage
Kenmore dryer start switch needs to be replaced
Depending on age of unit.. there are 2 screws on each side of the console (older unit) on newer unit you have 2 white plastic covers.. pop those out and unscrew the 2 screws and lift up the console.. you have to get to the starter switch from the back of console.. good luck..
Jan 21, 2009 | Kenmore 63942 Dryer
GE GTDL200EMWW 27" Front-Load Electric Dryer with 7.0 cu. ft. Capacity, 5 Dry Cycles, 4 Heat Selections, Dewrinkle/Delicates Cycle, Quick Fluff and Auto Dry Logo
89 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
