Question about Lenovo B575-1450A5U 15.6 Laptop 1.6GHz 4GB 320GB DVDRW
Lenovo B575-1450A5U sd card driver - Lenovo B575-1450A5U 15.6 Laptop 1.6GHz 4GB 320GB DVDRW
We have a lenovo tab2 A8, with a 64 GB microSD card installed. With both netflix & amazon prime video, in options, there is no selection to download to the SD card instead of the internal storage.
First, go to Settings > Storage and check if the "Default write disk" is set to "SD card". Then go to Settings > Apps and swipe to the left until you get to "SD card". Below will be all the Apps that can be be moved to the external SD card. Click in the box on the right and another page will come up. About in the middle of the page will be "MOVE TO SD CARD" tab. Tap on it and wait until it finishes. Then go back and pick another App to move. You should be able to download apps directly to the external SD card. I haven't done that on this device and not all apps will download to the external SD card (the app maker can restrict downloads to only the internal memory. This tablet is one of the rare few Android devices that allow moving Apps to external memory.
May 25, 2017 | Amazon Tablets & eReaders
How do I use an SD card reader on a Lenovo tablet?
Sometimes when you insert sd card into a card reader, the card reader will not always work, I have had problems like this, so either try another USB port on the computer, or clean the contacts on both sd card & card reader.
Feb 23, 2015 | Lenovo Tablets & eReaders
How to remove write protection for SD cards
The issue may be with your card reader or your card, if you installed the driver with the SD in the port and in the lock position then it may have messed with the functionality of the port.
I suggest you move any/all files from the card and then format it, or re-install the driver that corresponds to your SD card reader on your computer. If you cant do anything with the SD card as is, then re-install the driver for the card reader first, then try to format or write to the card.
I had an issue with formatting a card while ago, if you try both solutions above then use a 3rd party formatting program. I will paste a link below.
https://www.sdcard.org/downloads/formatter_4
Hope this helps!
Apr 28, 2014 | Lenovo IdeaPad Computers & Internet
LENOVO SD CARD DUMMY UPSIDEDOWN
This is late but I have an answer. The same thing happened to me. All I had to do was poke a small needle (a paperclip works too) into the right side of the SD Card slot and wiggle it around a bit. It'll be out in at the most 20 seconds.
Mar 17, 2013 | Lenovo Computers & Internet
Sd card not working
may be you should install the card-reader driver first!
Jul 31, 2012 | Lenovo ThinkPad T420 14
Can't detect sd card
Try updating your card drivers or just clear your card or card head from any dust.
Apr 09, 2011 | Lenovo 3000 Y410 Laptop
I've inserted SD card 2 GB and its not detecting...
hi
push the card in the sd slot
go to device manager
go to the top icons and hover mouse over them
one of the last ones on the top right should say scan for new hardware
so click on the scan icon
the compute may or may not find it
then leaving the sd card inserted
restart the laptop
and hopefully it will be reconiized if not
go start
programs
windows updates
check for updates
windows may offer you the update to install the sd driver
But make sure you do all the updates
before you do this
www.lenovo.com go to support/downloads
find your make model and operating system
then scroll down to find the sd card driver
download it
install it
restart laptop
and hopefully it will be ok
please let us know if fixya fixed it for ya
Feb 19, 2011 | Lenovo 3000 N200 T7100 1.8G 1GB 160GB...
Sd card can't be picked up
go into the device manager after you have loaded the drivers for your device and see if its even seeing it. If it is then disable it then go and scan fo rplug and play products and it shoiuld see it. Please don't forget to rate this answer please. Thanks for using FixyA!
Dec 26, 2008 | Lenovo ThinkPad Z61m Notebook
Problem in card reader slot
http://dl.okglb.com/consumerdl.lenovo.com.cn/UserFiles/Driver/en/Downloads%20and%20Drivers/Y410/XP/LN1CAR29WW1.exe
if helped use rate fixya
Nov 08, 2008 | Lenovo 3000 Y410 (59012354) PC Notebook
Small memory card stucked inside SD memory card hole
vijju_rasala hello,
Please go to the following address, and insert your model number. There you can find specific instructions on how to open your laptop properly.
http://www-307.ibm.com/pc/support/site.wss/product.do?doctypeind=8&template=%2Fproductselection%2Flandingpages%2FonlinePublicationsLandingPage.vm&sitestyle=lenovo
Sep 08, 2008 | Lenovo 3000 Y410 Notebook
Lenovo B575-1450A5U 15.6 Laptop 1.6GHz 4GB 320GB DVDRW Logo
95 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
