Question about GE (PSS26MSRSS) Side by Side Refrigerator
How to unplug icemaker from GE PSSS3RGXA
Need to remove icemaker for repair. Does it simply unplug from the back panel??
4 Suggested Answers
SOURCE: GE side-by-side: freezer making grinding noise.
did it sound like someone snoring in your freezer? that is your icemaker trying to eject cubes, and that noise in and of itself, is nothing to be worried about, that is normal. however, if your icemaker was failing to produce ice, when your husband removed the icemaker, was it near overflowing with ice, or did it look like it just had what would be a normal amount, i.e., the ice in the mold was little more than helfway. if it seemed like it was a normal amount of ice, then the heater on the bottom of the icemaker failed, replace the icemaker. if you had an abundance of ice in the icemaker, you may have a problem with either your water vavle solenoid not closing completely, or the icemaker motor itself is slow, causing the valve to be open too long. without checking it personally, i cant advise either way
Posted on Feb 15, 2010
Testimonial: "Thank you for your fast reply. The icemaker produced a lot of ice. I will take your advice and go from there. :)"
Sea Breeze
  • 4655 Answers
SOURCE: how do you remove the back panel of a PSC23NSTSS
Behind that cardboard there will be a drain exit that fill a pan that the fan blows over. But the correct way would be through the entrance and that is found inside the rear wall of freezer. Let me see if I can find some illustrations. Sea Breeze
Posted on Mar 27, 2010
  • 2006 Answers
SOURCE: Our GE Profile TFH22PR freezer
The problem is in your defrost system and could be either the heating element http://www.searspartsdirect.com/partsdirect/part-number/GE-Parts/Refrigerator-Parts/WR51X442/0046/363/Model-TFH22PRRAWW/0432/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=TFH22PRRAWW&subCompDesc=Freezer%20section&brandDesc=GE&modelDesc=93-GE-PROFILE-DISP&blt=11 or the defrost thermostat http://www.searspartsdirect.com/partsdirect/part-number/GE-Parts/Refrigerator-Parts/WR50X122/0046/363/Model-TFH22PRRAWW/0432/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=TFH22PRRAWW&subCompDesc=Freezer%20section&brandDesc=GE&modelDesc=93-GE-PROFILE-DISP&blt=11 or the defrost control aka defrost timer http://www.searspartsdirect.com/partsdirect/part-number/GE-Parts/Refrigerator-Parts/WR9X489/0046/363/Model-TFH22PRRAWW/0432/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=TFH22PRRAWW&subCompDesc=Freezer%20section&brandDesc=GE&modelDesc=93-GE-PROFILE-DISP&blt=11
So if you replace all three you have approximately $100 in parts, but all three can be check with an ohm meter to find out which one is bad.
They are also not that difficult to replace and this layout http://www.searspartsdirect.com/partsdirect/part-number/GE-Parts/Refrigerator-Parts/WR9X489/0046/363/Model-TFH22PRRAWW/0432/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=TFH22PRRAWW&subCompDesc=Freezer%20section&brandDesc=GE&modelDesc=93-GE-PROFILE-DISP&blt=11 will ive you an idea of where you will find them, if you are going to do the repair yourself. If you do make sure that you unplug the unit from the wall and that you remove everything from the freezer side to make sure you have room to work. You can use a hair dryer to defrost your unit for not and it will work for a week or so until the parts arrive.
Posted on Jun 20, 2011
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded ยท How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    How to remove samsung imc701 icemaker from refridgerator
    Take out the ice bin, remove the side panel with a screwdriver, press down the lever on the front middle top of ice maker and slide out the icemaker, unplug the wiring on the side, you're done.
    Jul 26, 2011 | GE Profile Energy Star? PFSS6SMXSS...
    GE Fridge icemaker is not working - Help!!
    I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
    Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
    I have a 15 year old GE fridge with an icemaker that has started
    You can buy a new icemaker from Home Depot your is probably rotted. Unplug the appliance and unplug the icemaker then remove the screws.
    Sep 24, 2009 | Refrigerators
    GE PSS26GRE SS not dispensing ice
    The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
    If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
    Thank you for contacting Fixya.com
    Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Water in Bottom of Refrigerator/How disconnect icemaker
    Hi, Remove the ice maker by loosening the screws that hold it to the wall. Once it is loose, there is enough wire that you can unplug the icemaker and set it aside. Now remove the rear panel and you can unplug the drain. Be sure and flush hot water through the drain to be sure it is oen.
    I hope this helps you.
    Please let me know if I can assist you further.
    Vic
    May 23, 2009 | Refrigerators
    Replacing icemaker in GE GSH25JSTE side by side refrigerator.
    generally its very easy. for your model it looks like the icemaker goes across the rear of the freezer section. if you will look on the left hand wall on the icemaker you will see a philips head screw remove this screw and pull the icemaker towards you and it will come out then unplug the wiring harness (this is probably the hardest part) there are 2 clips that keep the harness connected securley and you sometimes have to use a small blade screw driver to release them. onec icemaker is removed you have to remove the fill cup and the end stop off of the icemaker and reinstall on the new icemaker. one done just reinstall and turn it on. youre done!! BTW the new icemaker mostlikely will not have the green light the old one did so dont think youve got the wrong icemaker.. let me know if you need any further help Thanks Peyton
    Mar 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
    How do I remove the control panel on model JE2160
    You need to take the back cover off using a special tork wrench. If you don't have one a thin blade screw driver usually works. after getting the back cover off access is pretty easy to remove the screws from the panel. Make sure to discharge the capacitor before attempting any repairs and unplugged of course.
    Jan 12, 2009 | GE JE2160 Microwave Oven
    Replacing the ice maker mechanism on a GE side by side
    1. Unplug the refrigerator.
    2. Remove the icemaker's front cover by unscrewing or prying it off as needed
    3. Remove the ice bin, shelves, and vertical partition.
    4. Remove remaining screws, disconnect the icemaker wires from the harness connector or socket, and remove the unit from the freezer.
    5. Remove the back access panel and any fasteners that hold the inlet valve to the refrigerator.
    Jul 06, 2008 | GE GSS25SGMBS Side by Side Refrigerator
    Icemaker noise and malfunction
    on the back wall just above or under the fill tube youl find the wire harness , simply unplug the ice maker, while your at it 3 1/4 screws mount the ice maker to the side wall, youll have more room in freezer by removing it
    Feb 19, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Gene Tuck
