Question about Philips 50PL9126D/37B 50" DLP TV
I own a Philips DLP television model 50pl9126d/37 I just replaced the lamp on it less than 6 months ago and the red lamp failure light came on. I have opened the back and can see the lamp starting up for about 5 sec but then it quits. I have read a number of issues but was wondering if anyone who has had this similar problem figured out the solution. I have pulled out the lamp ballast but as far as I can see there is no sign of damage. When the ballast was in I removed the lamp and could see the ballast "firing" several times but Im not sure what to do at this point. Thank you for any help!
    Top Expert:
  • Philips Master
  • 14,553 Answers
You might want to with a flashlight and or small mirror want to look where the lamp faces at the color wheel---it must be intact and not missing any segments
typical color wheel:
I own a Philips DLP television model 50pl9126d/37  - 12_3_2012_5_48_14_pm.jpgIf bad or not moving at correct speed set will turn lamp off quickly.
Posted on Dec 03, 2012
  • 35 Answers
SOURCE: my DLP tv will not turn on the power button flashs
have you changed the lamp? J.D.W.
Posted on Jun 18, 2009
SOURCE: TV tries to start up but red bulb indicator comes on, no picture
In this case we would need more specifications. discountdashmerchantdotcom
Posted on Jul 29, 2009
  • 10 Answers
SOURCE: Do I need a new lamp?
99% chance your lamp needs to be replaced. Prices are in $120 -180 range. Search for "50PL9126D/37 lamp". they are available with or Without cage. Version with cage is preferred because it will be easier to install it.
Posted on Oct 08, 2009
SOURCE: need a lamp in my philips 50PL9126D/37 TV
Unplug unit and remove lower back panel should be 2 screws on each side and a few across the middle. Pull panel back and you should see a black box with metal folding handle. Remove the two left screws and pull out.
Posted on Apr 28, 2010
SOURCE: need to change lamp in philips hdtv model #
how do you get back panel off model 50PL9126D/37 philips tv ???
Posted on Jul 06, 2010
Where is the power board for a phillips 50inch model #50pl9126d/37
Hello
As far as the lamp stays lit for a few seconds, all other voltages comes to the lamp and inverter board are OK. If the lamp has reached its life time, this type of fault can occur.
Feb 16, 2012 | Philips 50PL9126D/37B 50" DLP TV
Phillps tv model number 50pl9126d/37 what is the red light mean
It depends on whether you are able to see a clear image or not. check the lamp first if its more than 2 yrs old you may need a new one, last one we checked with the problem you describe had a fan running slow. The fan nearest the lamp needs to run correctly or the tv will shut down. Good luck !
Nov 11, 2011 | Philips 50PL9126D/37B 50" DLP TV
Need to replace lamp moduule for modle 50pl9126d/37
Go to http://www.projectorlampsource.com/philips_50pl9126d_37_tv_lamp.html
Oct 29, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have Philips 50PL9126D/37 The red light on the front where the power indicator is keeps coming on. What does this mean? When it comes on my screen goes blank. Any suggestions?
The tv projection lamp in this tv been in the tv it like 2 years or more,tv in used daily like 4 or 5 hrs every day?The red LED light indicator is on,have a "LAMP"word written on the bazel frame?Yes,tv projection lamp life is over or eding.Tv reqire a new projection lamp.
Apr 05, 2011 | Philips 50PL9126D/37B 50" DLP TV
Need a lamp in my philips 50PL9126D/37 TV
Mar 28, 2010 | Philips 50PL9126D/37B 50" DLP TV
MY TV TURNS ON AND STAYS ON FOR 5SECONDS AND THEN THE SCREEN TURNS BLACK BUT CAN STILL HEAR THE SHOW PLAYING. TURNED IT OFF AND EVEN UNPLUGGED IT FOR ABOUT 5 MINUTES, BUT STILL THE SAME THING HAPPENS.
the lamp is likely bad .. they only work a few thousand hours .. then must be replaced .. your lamp can cost a couple of hundred (maybe even more if bought locally) .. here is one for less if you have someone handy that can change it.......
http://www.purelandsupply.com/50PL9126D-37-Bulb-Philips-DLP-TV-Bulbs.html
..... of course make sure power is off (unplugged) and make sure things are not hot .. there is usually a little cubby in the back where the lamp is located .. you an see what the lamp looks like at the above URL .. dont get finger prints on the bulb . that will cause it to crack when hot .. if you are unable to change the bulb then a call to philips service should do the trick. make sure you ask what the bulb replacement and labor will cost ..
Jan 27, 2010 | Philips 50PL9126D/37B 50" DLP TV
Oct 08, 2009 | Philips Televison & Video
Philips 50PL9126D/37B 50" DLP TV Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
