Question about Dacor Epicure ER48D Stainless Steel Gas Kitchen Range
Replace oven door gasket dacor er48d range - Dacor Epicure ER48D Stainless Steel Gas Kitchen Range
SOURCE: Dacor oven will no heat.
This solution worked for me. My gas oven would not work even though my burners would. There were 6 screws to undo and I removed the screen that led to the thermostat. Note: the reset button is located on the top of the thermostat and is red (actually is a square red button) - it is behind another round metal disk (that you first will see after removing the metal screen) with wires plugged into to but if you look from the front side view you will see it behind the disk. I reached back with my finger and pressed it down to reset. Thanks all for this great tip - saved me a service call!
Posted on Dec 24, 2007
jumptrout51
  • 3361 Answers
SOURCE: Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
Posted on May 05, 2009
SOURCE: Dacor oven light bulb
Yeah, it's a rip-off isn't it? Been there. :-( Find the bulb part number or electrical values and search eBay. I think this is what you're looking for:
G4 halogen 12v 10w, dacor part 86364.
A search right now shows multiple vendors offering 10-piece packs for $7.00 including shipping. I'm about to order a set myself.
Posted on Nov 24, 2009
SOURCE: How to replace glass on oven door - Dacor Epicure
You need to take the door off. There little hooks on hinges, that you move to up position and then lift up the door and it comes out. After that unscrew allt he screws, that you see.
Hope it helps.
Dacor range repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 07, 2010
  • 83 Answers
SOURCE: Dacor Epicure ER48D Stainless Steel Gas Kitchen
go to this website for your reviews and ratings www.retrevo.com
Posted on Sep 17, 2010
Describe your dacor rsd30 new oven door Problem - the glass is broken in the window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Nov 26, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Ovens will not respond. There is a F90 blip on the screen which appears to be an error message. Nothing in manuals describing such a fault or how to correct.
F-90 Cables to door latch loose or defective.
OR
Read more
Defective door latch assembly.
TheMobilian: Recommendations:
Tighten connections or repair cable.
: OR
Replace door latch assembly.
Dacor Troubleshooting Guide
Nov 25, 2010 | Dacor Epicure ER48D Stainless Steel Gas...
I have a Dacor ERD36, How do I remove and replace the oven door hinges?
most ovens , you open the door half way, then pull straight up the door will come right off, then you have full view of hinges and bolts
Oct 19, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
Hope it helps.
Feb 07, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
I want to install a 48" dual fuel range and I need to know the voltage and amperage to get the proper outlet and plug. It is also set up for propane and I'm hooking it to natural gas, I'd like to know if I...
YOU DON'T SAY IF THIS IS A DACOR CONCEPTS PRODUCT OR WHO MAKES IT..
IF IT IS, CALL THESE NUMBERS..
Dacor 1440 Bridge Gate Drive
Diamond Bar, CA 91765 Toll free: 800-793-0093 Main: 626-799-1000 Fax: 626-403-3130
Dec 18, 2008 | Dacor Epicure ER48D Stainless Steel Gas...
Range works, ovens do not
CALL DACOR DIRECT AND ASK FOR MICHAEL, HE IS THE SON OF THE OWNER.
Jul 09, 2008 | Dacor Epicure ER48D Stainless Steel Gas...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ER48D Stainless Steel Gas Kitchen Range Logo
35 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
