Question about Panasonic PT-43LC14 43" Rear Projection HDTV
TV won't turn on - just replaced lamp
After a message came on that we needed to replace the lamp we did this and we reset the timer on the tv and everything appeared to be working fine. After working normal for a few hours we turned the TV off and now it won't turn back on. When you press the power button the light flashes green for a minute and then returns to red. Any ideas?
This is for model # PT-43LC14
Thanks!
  • frozenfire70 Jan 11, 2009
    Same problem here. Sony Wega KDS-50A2000. Replaced lamp....screen lights for a brief second and goes off...sound stays on for a few minutes while no pic and then shuts off totally with red lamp light blinking. Tried to reset, picture won't stay on long enough to go through the menu and settings. Beginning to think it's deliberate on the part of Sony so you will call for service! Any ideas??
  • srevans04 Jan 20, 2009
    We just got a whole new replacement bulb and it seems to be working fine now.
    Thanks
  • 3 Answers
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. This review was the MOST helpful one, and I am sooooooooooooooooo happy it was posted. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board. Thank you! Thank you! Thank you!
Posted on Sep 21, 2009
    Scholar:
  • 73 Answers
I had this same problem. This (panasonic) set is sensitive to the type of bulb used. Don't use a remanufactured one, get a philips/osram or an OEM. If that is what you have, move on to the ballast. Replacing the ballast isn't easy, if you are electronically inclined, you can remove the back panel and the page size aluminum brace, it has two large square cut outs. The shiny silver box under that brace ( maybe 10" x 4") is the ballast. That is typically the next thing that goes out. The bad news is the cheapest I have ever been able to find a replacement was around $350. But again, if you have soldering skills, order a ballast repair kit from ebay ($30) and go to work. If you decide to do that, let me know and I'll email you photos and walk you through it. Once the ballast has been repaired, if it still has the problem, The power supply is bad. At that point take the bulb back out and sell it on ebay or send it back and use a LFH (large F****** hammer) and take out your aggression. Its not worth fixing. The powersupply board is more than the TV is worth. Most of the time this problem is fixed with the ballast. But its a CHORE to get to it and remove it to work on it. I'd be happy to help and I can send vids and pictures, depending on what you'd like to do.
Good Luck.
Posted on Jan 20, 2009
How to reset the lamp meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    I have a large screen panasonic tv. The lamp
    Turn On tv.
    Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
    Hope this info will help you.
    Thanks.
    Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    PT-61DLX75 replace lamp light reset
    To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
    Sep 20, 2009 | Panasonic PT-61DLX75 61" HDTV
    Set timer
    You did not post model number of TV so try below method to reset lamp timer.
    Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
    Jul 02, 2009 | Panasonic TY-LA1000 Projector Lamp for...
    Reset lamp life counter pt-50dl54j
    Feb 19, 2009 | Panasonic Televison & Video
    Replacing the projection lamp
    Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
    1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
    2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
    3. Press the remote 3 button, mute, then enter to reset the timer to zero.
    It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
    Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Projection lamp timer reset
    I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
    Jul 19, 2008 | Panasonic PT-44LCX65 Television
    Panasonic PT-43LC14 43" Rear Projection HDTV Logo
    746 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
