Question about Garden
Oil being blowend out of the fuel pump and smokeing
My lawn mower is bloweing oil out of my carburater and is smokeing. what do I do ?
  • 79 Answers
Its probably got a hole in the fuel pump diaphram just by pass the fuel pump and see what happens
Posted on Feb 13, 2013
  • 37 Answers
SOURCE: Heavy smoke when you first start the engine
Hi. sounds likes too much oil in engine or if you tilt the mower up&down or side to side.
if you need more help, just write again
Posted on Nov 21, 2008
  • 109 Answers
SOURCE: lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
  • 77 Answers
SOURCE: Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Posted on Aug 12, 2009
  • 68 Answers
SOURCE: Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Posted on Sep 06, 2009
Huskee lawn tractor
It does not sound like adjustments, sounds more like it is burning egine oil, this could be from valve stems or worn engine.
Sep 28, 2013 | Garden
Powermore 173cc OHV - suddenly running rough burning twice as much fuel as before. Blowing black smoke out of the exhaust. Is there a float that might be stuck open?
It.sounds like you have a hole in the float. If the float was.stuck, the oil would be filled with gasoline. With a hole in the float, the engine would flood, blow black smoke and run rough. Remember, black smoke is fuel, white smoke is water, and blue smoke is oil. Hope I helped.
Sep 04, 2013 | Garden
Blowing white smoke
to much oil in lawn mower need to drain some out fillt to line on dip stick
May 28, 2013 | Cub Cadet Garden
Blowing white smoke
Either the valve in the breather is not working properley and causing a pressure rather than a vacume in the crankcase, or the piron rings or cylinder bore are worn.
My mower smoke every now and then when mowing
Check the fuel pump and see if it is leaking oil,follow the hose from the dipstick tube to it and if the back of it is wet with oil then you likely need to replace the head gasket.If too much compression is leaking into the base of the motor due to a blown gasket then the pressure in the base will allow the oil to get to the pump and then into the fuel system,causing it to smoke[and burn oil].
May 19, 2010 | Yard Machines 155 Torque Briggs Stratton...
I'm blowing oil out of the fuel pump
if you have mechanical fuel pump, actuated by a cam or lever through the case wall, your gasket is probably faulty. check for replacement gasket, and or maybe you have 56 quarts too much oil in crankcase.
Apr 06, 2010 | Parks Optical 13.5hp Briggs And Stratton...
MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Jun 14, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
