Laptop turning off
My Advent Roma 1001 keeps turning itself off about 5-10mins after starting up. Pretty sure it's not overheating as its not hot, just crashes on me. It won't turn back on for maybe 20mins or so. If power is connected then the power on light is lit, but if disconnected it is off. It is impossible to turn it back on until its "ready" to do so. Any help greatly appreciated.
  • 7,627 Answers
Have you cleaned the areas around the fan and vents? Is it getting sufficent air flow? A laptop cooler is a option. You may have to open to verify that it's clean. I don't know the age, make, model of the machine. Does it do the same without battery? Has it been left on for extended periods of time? Plugged in for long periods of time? Hard to say exactly? Have you looked at the power options?
Posted on Dec 03, 2012
  • 2 more comments
  • Stephen Tinnion Dec 03, 2012
    I'm pretty sure it's not overheating, it's not heating up, that you can feel, just normal warmth from a laptop.
    I don't have that info either, im afraid, it's no actually mine, borrowed from my dad, and I'm away from the country for 6 months.
    Had it stay on for about an hour earlier, whilst a film was running, and it seemed ok. But then switched off again. Managed to run it in safe mode, and was able to get in for a good while without a problem.
    Any suggestions?
  • max carson
    max carson Dec 03, 2012
    You mentioned you you were away from the country, Is the AC different Volts, Hertz? Are you using a AC adapter? As in Plug type ? Anything change involving the AC?
    Not 100% sure on the volts/hertz situation, I will check when I'm home later. This could be an issue, with power surges? Only thing that wouldn't make sense is that for over 2 months it's been used on the same power without an issue.
    I was able to use media player last night for over an hour with no problem...
  • max carson
    Maybe just a glitch in the machine/AC. Stranger things have happened.
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Can't boot up laptop
If your Usb port works, then the mobo is working, so possible graphics problem. Try booting up in safe mode(normally pressing F8) on boot up then highlight 'start windows in safe mode', to see if Windows will load with only minimal drivers, if so restart again, pressing F8 again, but this time highlight 'start windows with last known good configuration' Doing any of these 2 things can be done in any order, either last known good config first or safe mode.
Posted on Oct 23, 2006
euanajbarnet
SOURCE: my screen on the advent roma 1000 goes dark
try pressing fn and f4 buttons simultaneously
Posted on Jul 18, 2010
  • 31 Answers
SOURCE: Advent Roma 1001 laptop. Turning on the laptop via
The fact that the laptop is recognising the battery's presence and yet is not receiving any power from it is not a good sign I'm afraid. There are batteries available online for around £40 but you may want to take the laptop to a repair centre first where they can usually tell you (for around £7-£10) if it is definitely a battery malfunction or not before you splash out on a new one.
Sorry I can't be any more help, battery issues are usually pretty black and white, they're either broken or working. Hope you manage to get it sorted either way.
Posted on Mar 01, 2011
How do I turn off safe mode on an Advent Roma 3001
You can boot in safe mode and open "MSCONFIG" via the RUN option on the start menu. If it not on the start menu look all programs> accessories> run. in the RUN Box Type msconfig and enter. That will open System Configuration, you will see options under General, you want the TOP one NORMAL startup, next click on BOOT tab and look for the Safe boot option,MAKE SURE IT IS NOT CHECKED. llet me know what happens or you need further assistance. max
Oct 31, 2012 | Computers & Internet
On my advent roma 2000 laptop, randomly the screen went black when i turn it on but it comes on at the start for 2 seconds then goes off..? what do i do
its overheating,check whether your fan is working, otherwise open it and clean it out, do not use a blower, the spinning fan can overcharge your motherboard and blow it
Oct 23, 2012 | Advent Computers & Internet
Advent roma 1001 factory settings
Hi There,
Change your internet options either in internet explorer or control panel. You've got the checkbox next to "proxy server" checked - uncheck it. That will fix the problem
Jun 06, 2012 | Computers & Internet
Advent roma 1001 memory slot locations
Never heard of it. Most times the memory slots are under the bottom of the laptop. If it is not there, then it has to be under the keyboard or palmrest.
Apr 23, 2012 | Computers & Internet
Advent Roma 1001 laptop. Turning on the laptop via the mains supply, the laptop springs to life and have no problems. The battery icon shows 100% charged and the battery l.e.d. light glows blue. Turn off...
Jan 17, 2011 | Advent Netbook
My screen on the advent roma 1000 goes dark
The usual culprits are loose connections (this only happens when the lid is moved forwards or backwards). The other is the LCD inverter getting too hot.
In both cases you will need to disassemble the laptop lid to check the leads and the inverter itself for dry joints.
If you're not comfortable with disassembling the laptop yourself then i recommend that you take it to a reputable repair store to have it looked at.
Regards.
Apr 12, 2010 | Computers & Internet
How do i turn on my built in web cam on my advent roma
Dear ambercrane37,
Try to run the CD driver for your advent roma and then click INSTALL when the CD start, then The windows should installed the web cam for you automatically. If you don't have the CD driver for your advent roma, try to obtain from where you purchase. Or visit the respective web address on the box of the product and choose the DOWNLOAD or SUPPORT tabs on their web pages.
GoodLuck!
Best Regards,
bionic23
Mar 27, 2010 | Computers & Internet
How do i use my built in webcam on roma advent 1000 roma laptop?
you cam use youcam software to open your web camera
Jan 11, 2010 | Computers & Internet
Advent webcam software
How can you just take pictures with the webcam on the Advent Roma 1001
Apr 05, 2008 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
