Philips 32pfl5604h turn up black
My TV will not boot up. When I turn it on, it flashes white diode on the front, but nothing else happens. Listen carefully you can hear a slight click as a relay when the diode lights will stop. My guess is that it's main board.
  • 1894 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
was that capacitor damaged?
Posted on Jan 11, 2008
Slinteriors
  • 8617 Answers
SOURCE: power up problem
i will need the model number of your set in order to help you with your problem. Please post the model number and I will try to help you out with the problem.
Posted on May 07, 2008
SOURCE: Replacing the Y-MAIN or Y-SUSTAIN Board in Philips 42PF9630A/#&
I called PTS 1-800-844-7871 they told me it was an easy fix. The part is $162.75. Im gonna try it.
Posted on Aug 16, 2008
SOURCE: Hitachi 50" Plasma (P50X01AU), power light comes on but no screen
Hope you already resolve it, if not, here what I went through 1. Try to get a service manual for your model ($10-18) from http://www.service-docs2.com or similar place. 2. Open the back and follow instructions how to remove and test the SDR-D and SDR-U board on the far left (take one off, see if you could see half the picture). Inpsect the chips on those two boards, you might be able to spot the burned out holes (that would be the defected board, seemed to be a known issue for particular models) 3. If it is the board, go to ebay and get the pulled out board replacement ($70-90) I fixed my 50 inch plasma this way
Posted on Jun 12, 2009
SOURCE: Sanyo DP42746 won't turn back on
I basically paid $1,000 a year to have this piece of grud. I am having the same problem everyone else is. It shuts off by it's self, then when I try to turn it back on, it shuts it self back off or the picture looks like its having a hard time showing. Very frustrated and feel ripped off.
Posted on Feb 26, 2010
Philips tv black image
From the stand point of cost to repair this I would just buy new.
Feb 02, 2017 | Philips Televison & Video
Won't turn on
Hello, please check +/- input capacitors 2052,2068 and 2071. Replace Diode 6307 (BY229X600). Also replace 2055 100uf/50V with 100uf/63V Best regards, Arpi
Jun 23, 2007 | Philips 50P8341 50" Rear Projection...
Philips 32pfl3505d/f7 tv wont turn on. The answer given says to snip one end of diode 621 but there is no d621 in the place marked. What else can I do?
Contact the authorized service center for Philips. If the TV doesn't turn ON, the most probable cause is with its main digital board. Replacing this board is a very skilled work, as it always need a firmware update. Firmware update procedure to Philips is rather more difficult than other brands; and not easly done by normal user. http://electronicshelponline.blogspot.com/
Mar 07, 2016 | Philips Televison & Video
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Philips 32PFL3505D/F7 32-Inch LCD HDTV keeps turning off when I turn it on
You have a shorted Diode in the power supply board.The power supply board has a 110 volt AC cord attached to it. Locate diode D621. It will be near the red, black and white wires attached to the inverter board. Snip this diode on one end and lift it just to clear the board. You may cut the other end and remove (don't have to). Do not try to tear the diode out or you will destroy the board. The TV will operate fine without this diode. Replace your ac fuse (4 AMP, GMA fast blow fuse ). You just repaired your TV. Thanks for asking, Matt of Martins TV.
Mar 03, 2013 | Philips 32PFL3505D 32 in LCD TV
Phillips 32 inch lcd will not turn on
What is status of Led lights on front of set?
Mar 14, 2012 | Philips 32PFL3505D 32 in LCD TV
Philips hd tv monitor 51pp9303h/17 dp TV 345 347he10839 TV receiver 3135020592 my screen is red and I tried to adjust the color nothing happen it still red can I fix myself
The model indicated is a older rear projection set.
If you go to a program that is black and white and turn the color off the screen should be something close to black and white.
There is a way to adjust the red screen down but it takes two people.
If you want to know how and what is involved let me know.
SD TECH
Jan 17, 2012 | Philips Televison & Video
Fuse keeps blowing in my philips 32pfl3505d/f7 tv
Good day!!!!
That problem is cause of shorted bridge diode or power mosfet..
just see the picture below to see the image of bridge diode and power mosfet..
If you don't have a tools or you have no electronic background you only have to is order the new power supply board..
I hope this solution will be helpful..Thanks for using fixya....
Sep 04, 2011 | Philips 32PFL3505D 32 in LCD TV
Is my tv digital model no wzh0932173832 Serial no 32pfl5604h/12
The model is 32pfl5604h/12. It has a digital tuner (DVB-T) for OTA but does not support HD digital signals OTA. You will need a set top box for HD digital (DVB-T2)
Philips has a support page with the manual and specs here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&grp=TV_GR&ctn=32PFL5604H/12&mid=Link_ProductInformation&hlt=Link_ProductInformation .
I hope this helps.
Mar 30, 2011 | Philips Televison & Video
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
