Question about Whirlpool GS6SHEXNL Side by Side Refrigerator
GS6SHEXNL Ice maker dripping water
Ice maker is working but water dripping from ice maker in several spots and dripping down the sides or tops of food on lower shelves
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Replace the water inlet valve assembly. It has a stuck solenoid. Here is the part to order.
Posted on Dec 03, 2012
  • 262 Answers
SOURCE: ice maker quit working
what happened you reset the computer (mother board) chances are you had a brief glitch in your power and it made the computer go hey wire
Posted on Dec 16, 2007
Master_Tech
  • 770 Answers
SOURCE: cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Posted on Aug 01, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Posted on Apr 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
Posted on May 20, 2009
Noticed 3 days ago. The ice tray was frozen solid to the top with water not ice cubes. looks like iceberg all the way back to where water line connects to ice maker. Now water had leaked somehow up to the...
What I have seen in a thing like this is a simple water valve drip. Some of them drip like a faucet. This causes the cubes to stick together and all kinds of grief. I have your service manual.
LG bottom mount ice box service manual
Feb 10, 2011 | LG LRBN20510WW Bottom Freezer Refrigerator
Stays in defrost too long. ice in the ice maker melt together. drips water inside the frezzer, changed the defrost thermostat & the mother board witch has the defrost timer in it. what is the ohms...
how is the food?is the ice cream getting soft? are you just having problems with the ice melting?you could have a bad water valve,water could be leaking past the valve,overflowing into the bin and will drip down,with the heater it's gonna work or not work when it should,there's a heater in the ice maker also
Mar 20, 2010 | Hotpoint HSS25GFP Side by Side...
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
I have a Jenn-aire JSD2695KES - it is a side by side, a couple of years old with an ice maker. Ice gets jammed in the last ice spot in my ice maker. It has been getting stuck in other spots lately, too,...
That sounds like a frozen over water fill tube due to a leaking water control valve. You may need to pull the ice maker out to see it but what you described is what happens when this happens. If frozen over the water will still come out on some models because there is a split in the top of the fill tube. Or something needs corrected on the amount of water time is OK for your ice maker. let me see if I can find the service manual for your model Be back soon Sea Breeze
Sep 21, 2009 | Refrigerators
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
The ice maker doesnt work, and in the day several times appears water in the floor, in the side of the door of the ice maker
Uplug refrigerator and remove the ice maker so we can look at the tube that comes into the back of the ice maker. It maybe the ice maker is calling for water but ice or a crack in the tube that delivers the water is being deverted to inside the freezer area. Also look behind the fresh food compartment door and see if you can send me the model number so I will be able to go over the correct model. Let me know, Thanks, Sea Breeze
May 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Nov 29, 2008 | GE GSS20IEP Side by Side Refrigerator
Whirlpool GS6SHEXNL not making ice
To start let's make sure that the wire we lift to stop the ice when that bucket is full, is in the down position. Now we can concentrate on two possible problems, one the water supply, two the ice maker itself. If you dip your finger in the ice maker, and it's dry then it's a water supply problem. This can be as simple as a kinked supply tube, a bad solenoid (to find it follow water line). It could also be the mechanics in the maker that control the solenoid are stuck or broken, in that case a new maker is needed. Before we go on, make sure the maker's is fully plugged in for power, and if you know how, check to see if the socket, it plugs in, has power. If we have power and you feel hard cubes in the maker ready to be pushed out, then the problem is in the maker itself and will probably need replacement.
hope this helps
Dec 13, 2007 | Whirlpool GS6SHEXNL Side by Side...
Whirlpool GS6SHEXNL Side by Side Refrigerator Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
