Question about Onkyo Audio Players & Recorders
Ir receiver on onkyo tx-sr602 won't work - Onkyo Audio Players & Recorders
  • 905 Answers
SOURCE: onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Posted on Oct 31, 2008
  • 24 Answers
SOURCE: onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
Posted on Dec 29, 2008
  • 151 Answers
SOURCE: Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
marsrover
  • 682 Answers
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Posted on Apr 09, 2009
  • 137 Answers
SOURCE: how can I reset Onkyo receiver TX-SR602 without
press and hold vcr 1 button and then push power button, it will reset
Posted on Apr 14, 2010
Testimonial: "You are genius and excellent, thank you for your help!"
I HAVE A TX-SR602 ONKYO AV RECIEVER AND HAVING PROBLEMS WHEN SWITCHING TO DIFFERENT AUDIO SETTINGS (EXCEPT FOR DIRECT) THE SOUNDS ARE STATIC SOUNDING, LOUD AND JUST DOES NOT SOUND GOOD. I WOULD LIKE TO...
Your problem is in your DSP circuit. This what makes your different soround sound options.
Coil L921 which is located on the DSP board may have opened due to in rush current.
Check coil L921, if open, replace it with a new and improved coil.
The Onkyo part# is 231237M022R2.
Jun 06, 2012 | Onkyo TX-SR602 Receiver
Onkyo tx-sr602 no sound output
Check for your + and - 15Volts DC and + and - 7Volts DC. If they are not there, check the Regulators on that line and the resistors on that line.
May 09, 2012 | Onkyo TX-SR602 Receiver
How can I reset Onkyo receiver TX-SR602 without remote control?
Apr 14, 2010 | Onkyo TX-SR605 Receiver
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
Protect Mode on. Want to repair/return to normal
Sounds like your receiver is fried. Your best choice is probably to take it to a repair facility, where they can figure out what component failed, or to buy a new receiver.
May 18, 2009 | Onkyo TX-SR602 Receiver
Hope this helps.
CABLE GUY.
Jan 06, 2009 | Onkyo TX-SR602 Receiver
Onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Dec 29, 2008 | Onkyo TX-SR602 Receiver
Onkyo TX-SR502 AV receiver
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Apr 14, 2008 | Onkyo TX-SR602 Receiver
42 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
