Question about Sew Pro QuickStitch SP-402 Mechanical Sewing Machine
My ppo sew machine zz401will move forward but not sew how can i fix this at home
  • Sew Pro Master
  • 1,564 Answers
I'm sorry... please elaborate. This question makes no sense.
Posted on Dec 04, 2012
The feed dogs on my brother sewing machine is not moving the fabric. It will move it if I sew in reverse but not forward. What could the problem be? How can I fix it?
Um. A feed dog pretty much always moves fabric forward. Only time I can think of that it doesn't ...you might need to push down the ...had to go down the hall and retrieve my machine's manual.. Forgot the name of the parts. On top of the left end of your machine, press down on the 'darner'. Knob on the top of that side of any machine. It regulates the pressure on the top thread. It thinks I'm not being clear, but it is 4:30 am.
Jan 22, 2018 | Brother Sewing Machines
I have a sewing machine and it will not sew right it is sewing backwise how can I make it go forward.
there is a forward / backward knob/ lever on the machine which you move to get the direction
the book will show it as a direction or walking foot movement direction lever or knob
Jan 20, 2016 | Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
CI just got my sewing maching six month ago and now for the first time it giving me problem . whenever im sewing the fabric won't move please please !!! help me to fix the problem.
in the needle plate area you'll find the feed dogs, they move the fabric forward as you sew, they should be up to sew . most sewing machine have a lever or knob that can be moved to change the feed dog position, unless then knob is broken
Aug 04, 2011 | Sewing Machines
New home SR 2100 sewing in reverse when it should sew
You need to take the machine in for adjustment, on that model you cannot do it yourself
Jun 26, 2010 | Sewing Machines
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
Very old Necchi sewing machine - sews in place
sounds like the feed dogs may be down or not working. Watch to see if the little teeth are moving under the pressure foot when you stitch( try to run unthreaded and with foot up no fabricto check) May be a button to turn up the feed dogs.
Oct 27, 2008 | Necchi 3101 Mechanical Sewing Machine
Sew Pro QuickStitch SP-402 Mechanical Sewing Machine Logo
Top Sew Pro Sewing Machines Experts
Steve
Jamie Sewell
Level 1 Expert
ray gallant
Are you a Sew Pro Sewing Machine Expert? Answer questions, earn points and help others
