Question about Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator
Samsung Refrigerator French Doors does not dispense the ice it makes.
Brand new frig! 29 cu ft. Samsung - 29.0 Cu. Ft. French Door Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel SKU: 2146814
2 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: 27 cu. ft. samsung refrigerator, side by side with
Troubleshooting an Ice Maker that won't Make Ice
Troubleshooting an ice maker is very important if you have problems with it. If you are having problems making ice with your ice maker then this is a very serious issue which will need to correct. If you are suffering from problems with your ice maker then there are a few simple things that you can do to diagnose and correct the problem yourself.
Checking the LinesThe first thing that you should do is check the water supply lines to ensure that they are not blocked. Sometimes ice can block the lines which may mean that they need to be cleaned out.
If the fill tube is frozen then this might need to be defrosted so that you can use it again. If the tube is too badly damaged then it might need to be replaced.
Broken LinesIf the lines break or become damaged then they can prevent water from getting to the ice maker. In this case the lines will need to be replaced so that you can restore the functioning of your ice maker.
Not Connected to WaterIt's also worthwhile checking the connections between your freezer and the water lines. If your freezer is not connected to the water lines, or if the tap is turned off then this will cause the same problems. There will not be any water available to make into ice. This is a very easy problem to correct and shouldn't take long to identify.
If you are not able to get any water from your freezer either then this suggests it could be a problem with the water supply. You will probably hear a buzzing noise when you're trying to make ice, this means that the freezer is trying to pump water which isn't available.
ValvesThe valve which is connected to the tap could also be damaged or broken. Check the valve opens and closes correctly and consider replacing it if it is damaged.
Too WarmIf the freezer is set to a too warm temperature then this will also create problems with producing ice. You will also notice that this isn't keeping your food as long as it should do. To correct this problem you will need to change the thermostat on your freezer so that it is lower.
Checking the Bail WireThere is a bail wire inside the ice maker which will lift when the ice maker is full of ice. This is designed to prevent too much ice being produced. If the bail wire is stuck in the up position then this will be preventing ice production.
Check the position of the bail wire by locating it inside your freezer. The instruction manual should help you to locate this wire.
SolenoidUnplug the freezer and pull it out from the wall. The water will travel to a solenoid located at the back of your freezer before being sent to the ice maker. If the solenoid is not working or is not getting power then this could be a reason for concern. If you're not skilled at home electronics then you might want to hire a specialist to help compete this task for you
Good luck
Posted on Jul 14, 2010
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
I have a Samsung French door refrigerator......29 cu ft. The problem is with the icemaker (again). The first icemaker went out just after the warranty expired so I ordered one online and installed it...
I'd pack all the frozen food (and ice cubes) in a plastic bin and wrap with blankets or towels to keep frozen and let the freezer thaw. Can speed it up with a heat gun or hair dryer. There's a good chance the thaw will free up the tray and let cubes flow again.
Apr 02, 2017 | Samsung RFG297AAPN (29 cu ft) Bottom...
Timer is making a rattling noise. where is it located on an ed25gwxxwoo frig
usually behind the light shroud in the back of the fridge section . Check under the kick panel under the doors.
Oct 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Jun 07, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator Logo
126 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
