Question about Pool & Spa
I have a density riverspas hot tub and it is stuck in sleep mode and there for won't heat up how do I take my density riverspas hot tub out of sleep mode
  • 1,631 Answers
Difficult to answer without knowing the "Brand" of your Spa Support Pak System. Lets presume you have the most common basic pak available - Balboa.
Press "Temp" button and then immediately press "Light". You will then sequence between 3 modes:
  • Economy - may display as Ec
  • Standard - may display as Std or St
  • Sleep - may display as Sl
Should save last setting
Posted on Dec 18, 2012
3 Suggested Answers
  • 12 Answers
SOURCE: temperature buttons on hot tub won't change
If you can remove the touch pad without damaging any wiring and such, physically eyeball the electronic board. It may have been incontact with water and burnt a resistor or shorted a pathway. You will see a discoloration in the area that is effected. If you don't see anything obviouse, procure yourself a can of electronic cleaner spray and spray the underside of the board. leaving it loose, and also with tennis shoes on, start it back up and run through your push button cycle. If that doesn't work, it maynot be the control board, it may be one of your acuators that is a faul. Check the easy stuff first, but look hard for a small burnt spot on the board, usually around a resistor. If you foind one, go online and find a color code chart for resistors, thats if you have any resistors on the board. Look at the resistor and write down the colored rings in order. The code of a resistor is how much resistance that resistor is supposed to operate at, or how much resistance it provides so that the unit as a whole can orerate. The color closest to one of the ends of the resistor is the one you write down first. So, you see 2 different colors on either side and ones black on one side and the other is red. Looking at it closley, you see the red ring is 1 cm away and the black ring is 3 cm away from its end. The closest to the end is your begining color code combination. so (all of this is ofcourse Hypathetical but for teaching, it's nessicary), you write down red, then the next color then the next till you reach the end for all intence purposes is black. and with this information, locate a reistor color code chart online or if all fails, ro to Radio shack and purchase one there, a few cents probably, and locate the same, exact!! color scheme of the one you think is bad. Once you locate it, the chart will inform you of how much resistance it is supposed to hold. With this newly found infomation take your Fluke or other electronic metering device, (Volt meter) and check the resistace as you would just like checking the volts on your car batterie with the volt meter. If the chart says it has an impeadance of 25 Ohms and you are getting nothing or its over the printed limit then it bad. Go to your trusty Radio Shack and buy a new 0.15 cent resistor and heat the solder being careful to touch nothing else and remove the old and replace with the new the exact way the old came out. if the red stripe was at the top then put it back the same way, at the top. If you fail to do so, it will not work period. It's designed to allow flow one way. Sorry for the long winded type but I bought a Buick Regal for $100.00 in mint condition because the repair shop told him he needed a new electronic main control board. I spent 5 hrs. checking impeadance and once I found the 2 that read the wrong resistance, I went to radio shack and spent $1.08 then replaced them and she started up like it was anew car. Good luck again, I appologize for the length of this but I hope it helps.
Posted on Sep 18, 2012
uspartscente
  • 717 Answers
SOURCE: in econ mode my 1998 spaform hot tub does not
in the economy mode it will only maintain a temperature so that it will not freeze. Economy mode is mostly for vacation time or for winter if you are not going to be using the hot tub for an extended period of time.
Put it into the standard mode and you will be able to have a HOT tub and will function as it should
US Parts Center
Posted on Aug 23, 2011
My spa is at 89 and its set for 104 and the pump will not cut on what is the problem
You may be in economy mode. Economy only heats the water during a programmed filter cycle. You want it to be in standard mode which turns on the hot tub once the water is 2 degrees below the desired temperature. There should be a mode or program button on your topside. One some systems you'll have to hit prog/mode button then the temp up button to change the mode. There is also a sleep mode. Never used it not sure what it's for.
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
Display code p=
Make sure the spa is not on sleep mode "SLP" or economy mode "ECO". Without knowing what type of spa you have it's hard to diagnose but it's possible your pressure sensor or high limit sensor it temporarily out of balance. If that's the case, it will resolve itself. If the problem persists you have a faulty faulty pressure switch or sensor.
May 05, 2013 | Pool & Spa
A downeast hot tub water is only 78 degrees turn up to 100 doesn't never get warmer and shows a ECn code
Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Apr 06, 2013 | Washing Machines
How do I return my hot tub to factory settings
to get your tub back to Std setting it is a matter of pushing the combination of the mode button if you have one or the temp button along with the jet button or the light button at the same time.
this sequence will go from Std, Economy or sleep mode.
Rod
US Parts Center
Feb 04, 2013 | Pool & Spa
Hot tub won't get hot
Check your filters and make sure they are clean.
Check to see if the heat indicator light is on when the tub is running.
Make sure the gate valves are open on either side of the pump and control box.
Are there any error codes in the little window on the topside?
Rod Kidman
www.uspartscenter.com
Nov 25, 2012 | Home
How to select hot tub covers?
Also check out Hottubworks.com as they have all patterns for Dream Maker.
Suggest you get a cover which is 2lb density which will last longer and has a doubled wrapped core. The cover will last allot longer than your original and keep more heat in. Here's link http://www.hottubworks.com/SpaCovers/Features.php
Oct 29, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I cant get my hot tub outof sleep mode
Try turning your GFCI breaker off then back on, may reset the tub's computer. Works on some.
Aug 18, 2012 | Dynasty Leisure Bay Dynasty Spas
SL display came on. Not heating.
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Hope this helps.
US Parts Center
Aug 31, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Pool & Spa Logo
134 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
