Question about Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio
Cobra LI7200 I just received a pair of Cobra 2 way Model LI7200 and I cannot get them to work with each other. I can pick up other people sometimes but I cannot communicate between the two radios. We are on the same channel and the volume is turned up. The call and the talk to not work.
  • 91 Answers
Dear sir, Pls see if u have same privacy code , pls turn of all privacy codes & sub codes keep every code "00" & keep same channel in both the radios , try now
Regards
raj
Posted on Apr 12, 2009
  • waqar raj
    waqar raj Apr 12, 2009
    Regards
    raj
2 Suggested Answers
  • 50 Answers
SOURCE: Cobra LI7200
Please don't touch any internal adjustments. It is like a 10 digit combination lock that is set to open. If you start changing the numbers, you will never get it open.
I think the problem is with your tone coded squelch (CTCSS). Your radio channel is like a telephone party line. If your CTCSS is not on, everytime you turn your radio on you will hear anyone on that channel that is close enough to hear.
If you are trying to use these radios for serious communications, that will drive you nuts to hear everybody else talking but not about what you need to hear. To try to mitigate this problem, CTCSS was created. There are 38 different codes. If you for example set your unit to operate on code 11 and your other unit is set to operate on code 12, you could not hear each other.
Now let's add a third unit set to not use CTCSS at all. Neither one of you will be able to hear this third unit but he can hear both of you. Now you set the second unit to code 11 like the first unit. Now you will be able to hear each other. The third unit will still be able to hear both of you but since he is not transmitting code 11, you still can't hear him.
If you are hearing some traffic, it is because they have their CTCSS set to the same code that you are set to. Look in you operators manual for CTCSS Privacy Codes. Set your radios accordingly and I think you will be in business. Let me know if this doesn't take care of you problem.
Posted on May 29, 2009
Cobra Bluetooth CB pairing problems
Did you hold the BT button for 4 seconds or for 6?
I would try it starting fresh- first without pulling the fuse and then with pulling the fuse first and waiting about 10 minutes before installing the fuse again. Then start with the procedure as if it never had been connected to a blue tooth phone.
If you do not have the manual anymore, it can be downloaded here:
https://www.cobra.com/downloads/29WXNWBT_MANL.pdf
Even if you have a different model CB, Cobra uses the same setup for most of their line.
Feb 14, 2012 | Cobra Radio Communications
I have a cobra cb for a rig. I can only pick up if iam right beside someone. If iam alittle ways behide I can only hear a word or two that they are saying. Is there something such as " a blue screw...
Odds are it is your antenna or coax more likely coax or a ground issue with them.
Make sure your antenna in mounted correctly a pinched coax can have a dramatic affect on reception.
Beyond that Cobra has a hit and miss record on quality control but there is no magical blue screw. There are 9 tuning coils that if tuned incorrectly will degrade or make your reception intolerable. A receive alignment for a reputable shop would improve the reception even though this is most likely not the problem.
It is possible that you have had quote "the front end" damaged referring to a pair of diodes but that usually happens when your radio is close to someone running a lot of power. Truckstops are good for that.
Aug 12, 2011 | Cobra Radio Communications
Why is there no audio on my Cobra MicroTalk radios?
Make sure they are on the same channel to pick each other,.
Apr 16, 2011 | Cobra MicroTalk FRS 110-2 (14 Channels)...
Cobra LI7200
May 29, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
No Auto Squelch on Cobra PR4700WX
Yes sir, when u will open the set u can find two potentiometers , one is for tranmitter another for receiver . Try adjusting the same ( second radio should be transmitting ) do not switch one radio without antennae it may burn ..
Regards
raj/
Dec 24, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
Sep 21, 2008 | Cobra PR-245/2 (7 Channels) 2-Way Radio
Cobra PR 260
Dear sir,
Try to operate in channel 1~7 , keep the maximum range extender button pressed for 5 seconds u will hear 2 beeps sounds. If it works Ok or else u need to change your Radio antennae
Sep 14, 2008 | Cobra PR 260-2WXVP Two Way Radio
Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio Logo
109 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
