Question about Meco 9210 Grill
I need a meco 9210 electric element
I just need to element, and not the element control unit. I think the part number is #17072401.
3 Suggested Answers
SOURCE: Meco 5030 Smoker Grill
Partial solution: Their phone number is 800-251-7558. Part number for the electric burner is 03072701. I don't see a thermostat control listed - sorry.
Posted on Jul 30, 2009
SOURCE: NEED instruction manual for MECO outdoor smoker -NOT electric
If you try searching for Meco on-line, you'll go nuts.
Check Aussie here's a link for the manual.
http://www.aussiegrills.com/images/product_elements_07/pdffiles/5024-5025-5028-5029P-Stainless-Water-Smoker.pdf
Posted on Sep 26, 2009
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Mobile home electric furnace multiple problems
Hello im not familiar with this model, but looking at the schematic for the models its similar to a heater blower. as you say it is heating up but only blowing cool are but the thermostat is turning off as its getting hot, the only thing i can find that would make it do this is if its blocked on the heater element, or the heater element is only half working, the device has a thermal fuse on the heating element this could also be a problem you would need to remove the try that hold the heater element ands test the heater element with a meter to see if its working if that's fine, then one of the thermal switches would be at fault. there is alot of model number for this brand but they all have the same setup. the panel for the heat looks like it only has 2 screws hold it in place, but disconnect the fuse before opening the unit. there is 2 setting on the heater elements that means there is 2 elements one top and one bottom in the case. there is also 2 thermostats on this model im looking at that are for the heater controls these would when they get to the temp required turn the elements on and off. there is also a thermal fuse that if the element gets to hot with turn it off. check these. remember dont open the unit until the power is off and disconnected from the mains supply . personally i would think the thermostat switches need replacing, these are cheap to replace the part number is on them use the same part number to get the right part ebay or heating suppliers will have these parts in stock, they wear out as they the only moving parts apart from the fan but thats working or you would not have cool air.
Jul 04, 2017 | Coleman Heating & Cooling
Cobra ESD 9210 Radar Detector for sale
USD 75 is what other used ESD 9210s are current going for here.
Jul 19, 2012 | ESD 9210 Radar Detector
I need a manuel for 9325 electric grill
You can get the manual on the link below. Scroll down to product details to download it.
http://www.amazon.com/Meco-Deluxe-Electric-Grill-Satin/dp/B0007XXNSQ
Good Luck
Jan 01, 2011 | Meco 9325 Grill
I bought a meco 5031 but the manual is to assemble the 5030 electric combo I have put it together as close as a can make of it. with 1 bolt and nut left over! but not sure how the metal ring, pan and racks...
Here is a link to a manual that shows both the 5030 and 5031. The assembly drawings for your unit starts on page 5. I hope this helps you get your unit going. Smoker food is sooooo good. lol
http://tinyurl.com/22rbgg2
Jun 29, 2010 | Meco 5031 All-in-One Grill / Smoker
I need the manuel for Meco electric charcole/water smoker serial no 5000
Could not find the Model 5000, but did find a 5030/5031 & 5029.
Suspect that these are all later models for the 5000 line and much of the operations and FAQ may be helpful.
You can view and/or download the manual at http://common.csnstores.com/common/marketing/meco/5030-Water-Smoker-Grill.pdf
good smokin and grillin
Apr 16, 2010 | Meco Grilling
Tel.mute
The Tel Mute function is controlled by the pink wire in the loom. Make sure it is not connected to anything.
A capacitor inside the unit has also known to cause this problem when it goes bad. This will have to be repaired by a tech. but you can le tthem know to look for C719 or C711 (I think C711 is printed on the pcb)
Apr 27, 2009 | Rockford Fosgate RFX-9210 CD Player
I need the electric burner for a Meco 5030 Water Smoker
Their phone number is 800-251-7558. Part # is 03072701. Good luck!
Dec 29, 2008 | Meco 5030 Smoker
Aug 31, 2008 | Meco 5025 Smoker
Jun 24, 2008 | Meco 5030 Smoker
Meco 9210 Grill Logo
60 people viewed this question
Top Meco Grilling Experts
ray gallant
Tom Chichester
Are you a Meco Grilling Expert? Answer questions, earn points and help others
