SOURCE: Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know [email protected]
SOURCE: The fan on my Carrier cental air system is on, and I can't
The fearute that is running your fan so often is designed to provide even, consistent temperatures throughout your home as opposed to hot spots and cold spots. Some customers find this feature to be an annoyance or a waste of electricity. IF you would like to be able to turn off that blower you can have it wired to a switch which would give you either manual off and on or even a timer.
If you want to do this in a barebones fashion you cojuld just find the circuit breaker that controls it and turn it off when you don't want to use any function of air, heat or cool.
SOURCE: carrier weathermaker 8000 won't turn on blinks red
check the filter. If its dirt, clean it, put it back and switch your unit on.
SOURCE: Carrier Weathermaker 8000, inducer fans runs,
No, the blower motor is supposed to run and dissipate most of the heat. It sounds like the blower motor isn't running.
SOURCE: My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
