Washer dosn't take fabric softener
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 03, 2012
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
farr64
  • 121 Answers
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Posted on Sep 14, 2009
beltronic205
  • 1466 Answers
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Posted on Nov 25, 2009
  • 15 Answers
SOURCE: The fabric softener is clogged with dried up
You really cant take them apart without breaking the dispensers. Fabric softner is basically wax and fragrance. Add very hot water to the dispenser to melt the fabric softner. In the future, water down the fabric softner.
Posted on Feb 14, 2010
SOURCE: kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Posted on Apr 18, 2010
The softer tray will not drain
Front Load Washer Troubleshooting: Clogged Dispenser ...
? 1:13
https://www.youtube.com/watch?v=KqQcyprw8j8
Dec 14, 2009 - Uploaded by ManageMyLife
Can you shed some light on why these aren't draining? ... Thosecompartment will stay filled with water after wash cycle. ...Whirlpool & Kenmore Washer Repair - Fabric Softener is NotDispensing - GHW9400PW1 - Duration: ...
Fabric Softener is Not Dispensing - GHW9400PW1 - YouTube
Nov 28, 2015 | LG WM2240CW Washer
Washer dosn't take the fabric conditioner
Washer dosn't take the fabric conditioner This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 03, 2012 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener compartment
You will need to clear the line from the fabric dispenser to the tub.
Oct 15, 2012 | Kenmore HE2 Plus Front Load Washer
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
I have an older Maytag washer without a user manual and was wondering if the cup in the top of the agitator was for adding fabric softener? If it is when do I add it and how much do I add? The model number...
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-A9200/3048/0153200/X2900731/00005?blt=06&prst=&shdMod= I thinking you are referring to item 7 which is listed as a dispensing cup. If I remember right it just sits on the agitator as a means to take off and use to measure soap, fabric softener. Since there is not a water flush line to it, I wouldn't use it to try to dispense the fabric softner. But it probably would do any harm to try it and see how much was actually left in the cup.
Jun 21, 2011 | Washing Machines
The fabric softener and bleach trays will no longer feed into the washer they stay full. Any ideas?
Just wondering by taking the top off & cleaning it would this solution be the same if the fabric softener tray has water in it after washing a load of clothes?
Jun 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
